Electrical question
Old Apr 7, 2009 | 01:31 AM
ominousracingteam's Avatar
ominousracingteam
Electrical question
i just recently installed a dvd/cd flip out deck in my truck and after i installed it the radio takes about 15 seconds to turn on after i turn the key on, as well as the windows wont roll down or anything until about 15 seconds later. wondering how i can fix this maybe its just a fuse?! i already replaced the f31 fuse because it popped when i was installing the stereo. just wondering if anyone has heard of this problem before?!?
thanks.
Old Apr 7, 2009 | 09:41 AM
jsoko's Avatar
jsoko
welcome to the site
did you disconnect the battery before you started your work?
possible that you connected to wrong wire
Old Apr 7, 2009 | 10:03 AM
Oldguy4's Avatar
Oldguy4
I think jsoko is on the right track. If it's a blown fuse it would never work. You've got everything wired to something that has a 15 second delay. Like when the interior lights go out?
Old Apr 7, 2009 | 02:43 PM
ominousracingteam
I'm 100% sure it's wired right because I even put the stock deck back In Thinking the aftermarket deck I bought was faulty but it still did the same thing with it all plugged back into the stock stereo. All
This happened after I popped the 20 amp f31 fuse and replaced it...don't know what it can be?!
Old Apr 8, 2009 | 08:49 AM
jsoko's Avatar
jsoko
disconnect power to radio,run a wire to the + side of battery, ground radio, use this temp. wire to see if you have the problem now, one way to trouble shoot it. (careful with that hot wire )
Old Apr 8, 2009 | 12:29 PM
ominousracingteam
I figured out what the problem was, fuse #1 was blown and apparently it runs the acc.(radio, wipers, windows, etc.) For the first 15 seconds then switches over to fuse #31 for continuing power. Thanks for all your help guys.
Old Apr 8, 2009 | 12:33 PM
jsoko's Avatar
jsoko
NO thank you
that info is now stored in memory bank
Old Apr 8, 2009 | 03:36 PM
Oldguy4's Avatar
Oldguy4
NO thank you
Ditto that!
Hybris
2009 - 2014 F150
Jan 3, 2016 07:32 PM
almbon
Dec 17, 2013 11:20 AM
BarnettMan85
2009 - 2014 F150
Feb 27, 2013 08:36 PM
jeffdoerr
Dec 13, 2010 12:00 PM
Sycostang67
Electrical Systems/Wiring
Aug 28, 2009 01:57 AM
