Carburetor Recommendation
Old Jul 13, 2009 | 09:16 PM
timmyt22's Avatar
timmyt22
4160 Problems
I had checked and set everthing on that carb when a guy at the speed shop told me to check the mating surface. Run a file on it and saw what he ment. Put the body on the mill and machined where the float bowls seal and bottom at throttle body. The secondary bowl surface casting was over .017 off. I think that is where it was flooding thru the metering plate gasket. Would not recommend this fix but I had nothing to lose. Thanks for the replies, Tim
Old Jul 14, 2009 | 08:18 PM
gearhed1971's Avatar
gearhed1971
I had the same problem with an Ebay carb I bought,leaking all over on the idle circuit.It turned out the "excellent mechanic" who sold it to me put the wrong metering plates in with mismatched gaskets.BEWARE EBAY!!!!
Nathan Vos
Jun 25, 2016 09:49 PM
LGx
19
Aug 4, 2013 03:28 PM
DanMan7
Jan 30, 2011 07:32 PM
Truckboy
Feb 9, 2009 11:50 PM
Bob_1
15
Sep 19, 2006 11:35 PM
