I need to find out where I can buy an O ring for the High Pressure Oil Pump. I have a 2000, 7.3 Turbo Deisel. According to Ford, you can't buy these, no part #, purchase the whole pump assembly only for $2K plus. The pump assembly is made by Bosch, but they can't sell the O rings either. Does anyone know where to buy? Or maybe a part # for a similar O ring?
Welcome to FTE Larry. Glad this got moved to the right section.
Which o-ring do you need? The ones on the lines, or the end plug? Either way, try this link Click Here
Do you know how to change the o-ring, or do you need some advice on how to do it? Guzzle usually includes instructions with his kits, but if not, we're here to help.
