Sponsored by: Real Truck
Need a quick answer - Hubs
Old Apr 6, 2009 | 04:57 PM
dew the thunder's Avatar
dew the thunder
I bought some new hubs for my truck and I don't have 4 wheel ABS. The hubs I received have the wires and such for ABS. Can I just cut them and not worry about it?
Old Apr 6, 2009 | 05:12 PM
eightrac's Avatar
eightrac
You can use them but I would send them back for the correct ones as the correct ones will be significantly cheaper.
Old Apr 6, 2009 | 05:16 PM
dew the thunder
It was the same price from this guy. And when I called local stores the ones without the ABS sensors were more expensive.
Old Apr 6, 2009 | 05:27 PM
superduty4x4's Avatar
superduty4x4
I'd remove the ABS wires and plug the holes with something else. Those wires aren't cheap!
Old Apr 6, 2009 | 05:31 PM
eightrac's Avatar
eightrac
They are $40 at napa and besides that, he doesn't need them. I'd say cut them and put some rtv over the nub to make it look good.
Old Apr 6, 2009 | 07:52 PM
dew the thunder
Well found something weird while doing this repair. There's a plug that was behind the fender lining that I always thought controlled some kinda entry lighting. Turns out that plug fit the ABS wiring perfectly. So I plugged it in and I'm gonna leave it. Anybody know if I'll gain anything or hurt anything by doing this?
Old Apr 7, 2009 | 09:33 AM
eightrac's Avatar
eightrac
You probably have 4 wheel abs. Does your abs light turn on witht he key in the "run" position?
Someone may have disabled it or has taken the abs bulb out of the cluster for a bad speed sensor.
Old Apr 7, 2009 | 10:15 AM
dchamberlain's Avatar
dchamberlain
I don't know what year it started, but by 2004 at least I believe all SD's had anti-lock brakes. Do you have rear disk brakes or rear drum brakes? If rear disks you may have ABS. Also, follow the brake lines out of the master cylinder. If they go into a big valve body looking thing with a lot of wires, you probably have ABS. It might be worth figuring it out and getting them to work. ABS has saved my *** more than a few times.
Old Apr 7, 2009 | 10:55 AM
DetailerDave's Avatar
DetailerDave
My 99 also has the ABS wires behind the fender liners in the front. I also found the replacement hubs with ABS wire much cheaper than without. Original didnt have, so I left alone and tied the wires up out of the way to the brake line. Havent had any problems since.
Old Apr 7, 2009 | 03:23 PM
dew the thunder
I have rear discs but I was under the assumption that you couldn't get a Super Duty with anything less than rear disc? And to tell the truth... I'd rather not have ABS. I've not had it on 3 vehicles and the whole time I was driving my parents vehicles waiting for the parts for this to get here I couldn't wait to get back to mine. Never been a fan of ABS.
SteelerSal
Jan 1, 2014 12:16 AM
stevestroke01
Dec 26, 2011 07:17 PM
stecz
Oct 10, 2010 04:12 PM
fordguy55
May 2, 2009 10:19 AM
molotov
Jan 23, 2008 09:27 PM
