Sponsored by: Real Truck
Heater control switch
Old Apr 6, 2009 | 04:37 PM
Davews's Avatar
Davews
I'm new here so please bear with me on this. I had a local mechanic repair my front hubs (vacuum seals) on my 2001 Super Duty 250 because they wouldn't disengage from 4X4. After picking the truck up I noticed my heater control switch won't control heat, defrost air etc...It only blows out the defrost where ever you put the setting. I've tried to trace the vacuum lines to see if one came off but I can't find anything. I'm trying to sell the truck now so was hoping to avoid another trip back to the mechanic (who says they did'nt touch the heater). Any ideas? Thanks, Dave
Old Apr 6, 2009 | 04:49 PM
Beach_Bob's Avatar
Beach_Bob
If you do a quick search you will find that your problem can be traced down to one of two problems. Either a bad vacuum switch (solenoid) or a leak in the vacuum line between the solenoid and the air blend gate.
The real experts will chime in, but they will need to know what engine you've got to help you out.
Old Apr 6, 2009 | 06:58 PM
RACERX7775's Avatar
RACERX7775
he probably knocked a vacuum line off when he was doing something on your hubs. sounds a bit shady to me. first the hubs stay locked, took it to a mechanic, repaired the vacuum issue with the hubs, got the truck back, hubs will unlock, but there is now a issue with the vacuum on the a/c controller..... bring it back and tell him to fix the original complaint and put back whatever he disconnected when he thought he was fixing.
Old Apr 6, 2009 | 07:21 PM
Furian's Avatar
Furian
You Keep What You Kill
Check to see if the ESOF is actually working in ON/OFF modes. The mechanic may have just disabled the ESOF because he thinks that you are selling the truck...
Old Apr 7, 2009 | 06:30 AM
Davews's Avatar
Davews
My engine is a 5.4 and I'm pretty sure the mechanic did what he said he did. The hubs were pulled apart and seem to engage / dis engage but as far as the vacuum line being knocked off I traced these lines from the hubs and get lost in the clutter inside the engine bay. Does anyone have a pic of what the vacuum solenoid looks like or where I should look? Thanks for the help, Dave
1980 Bullnose
Jan 20, 2014 04:45 PM
ddiercks
Jul 13, 2013 06:00 AM
Mr Dave73
1997 - 2003 F150
Nov 27, 2010 01:41 PM
wildjon300ci
Oct 9, 2002 03:14 PM
fordbigtruck
1947 and Older Ford Trucks
Jan 24, 2002 08:24 PM
