Oil Pan Bolt Pattern?
Old Apr 6, 2009 | 11:40 AM
berry1234's Avatar
berry1234
Is there a particular way to tighten the bolts on an oil pan? I assume it's similar to a tire maybe a cris-cross pattern?
Old Apr 6, 2009 | 12:05 PM
lasthighboy's Avatar
lasthighboy
i dont remember if there is a specific pattern or not, but its not real critical. i usually start in the middle and criss cross my way to the ends, just snug them up. i usually end up doing it five or six times at least because as you tighten the outside bolts it takes the pressure off of the middle ones so they are loose again. as you tighten the middle the outside becomes loose. just keep going over it and snug them up until they are all evenly snug. do not overtighten.
Old Apr 6, 2009 | 12:21 PM
fmc400's Avatar
fmc400
MSEE
Usually start in the middle, and criss-cross like lasthighboy said. The important thing is that you tighten them gradually so that the pan flange does not warp. If you're using a cork gasket, it's important to repeat this process a couple times because the gasket will relax, and you'll need to re-torque.
Old Apr 6, 2009 | 01:09 PM
berry1234's Avatar
berry1234
Thanks for the info.
clest82
6.7L Power Stroke Diesel
May 12, 2017 04:39 PM
T diesel
Apr 7, 2017 11:03 PM
Grimblore
Modular V10 (6.8l)
Jan 22, 2016 09:00 AM
makattack
Nov 13, 2015 09:32 AM
79 ranger
Oct 2, 2011 10:53 AM
