power window/auto locks
Old Apr 6, 2009 | 08:48 AM
CdnSoldier's Avatar
CdnSoldier
Fellas
My wifes power windows and auto door locks have stop working. The windows will roll down/up only using the drivers master buttons. The window lock is off.
The auto locks, the one that locks when you reach 20ks don't work either. Im stumped. The fuse is good, have reset the locks over and over. The one thing is the horn does not sound the second time when the auto lock is activated.
Any suggestions?
Old Apr 6, 2009 | 11:03 AM
noboston's Avatar
noboston
there are more then one fuse for this system . check the power dist.fuse panel under the hood and the interior fuse panel . I do not have the manual for your year car. good luck
Old Apr 6, 2009 | 08:00 PM
CdnSoldier's Avatar
CdnSoldier
All Fuses and CBs are good.
Old Apr 7, 2009 | 06:07 AM
noboston's Avatar
noboston
check for broken wires in the rubber door boot on the drivers side.this is a common problem. there are many threads on this forum check them out for more help.
Old Apr 7, 2009 | 12:27 PM
CdnSoldier's Avatar
CdnSoldier
The windows work now, damn gremlins. The auto drive locks still no go. I have done a seach with the same results. enable/disable, the only thing is the horn does not sound when it is activated (enabled). Im starting to think, it mybe the RAP?
Old Apr 8, 2009 | 10:05 PM
texan2004's Avatar
texan2004
Could be the GEM going bad. It controls an awful lot that of type stuff. Could also be the door wirng as stated above. I doubt three window switches crapped out at once. If the window problem and the door auto lock problem first presented themselves at the same time, I would be inclined to think the problem may be the GEM. My guesss is that the auto door lock problem and the horn notification problem are related.
hijo202
Apr 28, 2016 07:56 PM
Bootlegger's Deluxe
Dec 6, 2015 11:01 AM
Debdoodle
1997 - 2003 F150
Apr 12, 2015 11:48 AM
bearhugger
22
Apr 3, 2012 07:11 PM
Guy
Jul 7, 2002 03:23 PM
