General Automotive Discussion
changing the gear ratio-more...
Old Jun 20, 2000 | 02:21 AM
deedee's Avatar
deedee
my husband says there is a way to change the gear ratio without chaning the rear end. He says there is something you can buy to put on the truck that changes the ratio without the extreme expense, but he doesn't know what it is or where to get it. Does anyone know what he's talking about?
Old Jun 20, 2000 | 05:47 AM
Nathan's Avatar
Nathan
You can have a new ring and pinion installed. Ive seen this cost anywhere from $800-$1200 per axle.
Nathan
Old Jun 23, 2000 | 04:37 PM
mrlaserboy's Avatar
mrlaserboy
>know what it is or
>about?
You can have your rear axle re-geared to a different ratio- no need to swap the entire axle. Gears should run about $200, install kit about $150, and labor around $300. If you have a 4x4, then both axles should be done so you don't break the transfer case and a bunch of other driveline parts.
The only thing I can think of that your husband may be talking about would be the US Gear overdrive/underdrive units. They bolt onto the tranny/transfercase and either give you increased overdrive or underdrive on-demand. They, however, are not cheap at all- $2K+. You can get more information on these units from a good RV place.
Dustin Siebert
mrlaserboy(No Email Addresses In Posts!)
Registry: http://www.superford.org/cgi-bin/sf.cgi?uid=default&vr2=1&ID=201
Home Page: http://www.fortunecity.com/silverstone/gear/40
'88 Bronco XLT 302EFI/AOD/BW1356/44IFS with 8 lugs(open)/10.25 FF(Lockright locker)/4.56/6" Superlift complete/35's-street/38.5's-trails
2 BIG BRONCOS 4X4 CLUB - GREAT LAKES CHAPTER
Old Jun 27, 2000 | 05:17 PM
frankenstein's Avatar
frankenstein
Jan 28, 2010 07:01 AM
Hi-psi
Oct 27, 2005 06:25 PM
BFR250SD
Jul 1, 2005 09:18 PM
deedee
Jul 4, 2000 07:07 PM
CJay
Mar 16, 2000 05:38 PM
