Antifreeze disappearing
F350, automatic, 4x4 crew cab in stock trim other than an aftermarket intake/air cleaner housing and muffler delete.
Antifreeze has started disappearing at the rate of a gallon every two weeks.
No wet spots on the engine or under the truck.
Where or what should I tell him to look at or for?
I am at a total loss on Strokes, but I know where to ask questions to get good answers.
<TABLE style="WIDTH: 254pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=338 border=0 x:str><COLGROUP><COL style="WIDTH: 254pt; mso-width-source: userset; mso-width-alt: 12361" width=338><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; WIDTH: 254pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=338 height=17>Possible Sources (from the manual)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Coolant hoses or tubes</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Hose clamps</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Coolant pump O-ring seal or gasket</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Thermostat O-ring seal or gasket</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Thermostat housing</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Radiator</TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD class=xl26 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; WIDTH: 254pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 25.5pt; BACKGROUND-COLOR: transparent" width=338 height=34>Transmission fluid cooler (in radiator) (if equipped)
(may leak internally or externally)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Degas bottle</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Pressure relief cap</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Coolant pump leaking from weep hole</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Heater core</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Coolant crossover manifold assembly (if equipped)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Engine gaskets (may leak internally or externally)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Oil cooler (may leak internally or externally)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Heated PCV fitting (if equipped)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Cylinder block core plugs (if equipped)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Cylinder head core plugs (if equipped)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Block heater (if equipped)</TD></TR><TR style="HEIGHT: 13.5pt" height=18><TD class=xl27 style="BORDER-RIGHT: windowtext 1pt solid; BORDER-TOP: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 13.5pt; BACKGROUND-COLOR: transparent" height=18>EGR cooler(s) (diesel only)</TD></TR></TBODY></TABLE>
