replacement carb
Old Apr 5, 2009 | 08:59 PM
muskin's Avatar
muskin
replacement carb
Hi I have a 85 F150 300, everything is still factory, no upgrades. I was wondering what is a good replacement for the carb feedback carb. Something that is bolt up and go.
Thanks Barry
Old Apr 6, 2009 | 10:58 AM
AbandonedBronco's Avatar
AbandonedBronco
About the only replacement for the stock feedback carb that I know of is a stock non-feedback carb. That, however, requires that you replace the distributor and the ignition module. The final result will be the same, but you won't have to deal with a computer controlled carb.
If you want to put a little extra work into it, there are adapters to put a 2bbl on the 1bbl intake, but the stock intake is generally considered too restrictive to accommodate it.
