Sponsored by: Auxito
Radio removal
Old Apr 5, 2009 | 07:20 PM
earl82461's Avatar
earl82461
Radio removal
2003 F-150 with factory radio c/d player. Trying to remove this with no success. Have the removal tool. Push both in and can move the radio just a hair (1/16 of an inch). Any tips would be appreciated. Thanks in advance for your replys.
Old Apr 5, 2009 | 07:57 PM
Ron W.'s Avatar
Ron W.
The only time I've seen people not get the radio out using the correct tool was when they pushed the tool in further than it needs to go. Insert tool one side at a time and listen/feel it click in place, then gently push both outward at the same time.
Good luck.
Old Apr 6, 2009 | 05:33 AM
earl82461's Avatar
earl82461
Thanks Ron. Will give it another shot.
Old Apr 6, 2009 | 08:46 AM
galaxie641's Avatar
galaxie641
The push outward is the key, you are using the end of the tool in the radio to squeeze the tabs close to the radio and allow it to slip out.
Old Apr 6, 2009 | 03:26 PM
earl82461's Avatar
earl82461
galaxie641......Thanks. I am sure that will work. Will be a day or so until I can get back at it and will let you know the results.
jmcnjohn
Jan 16, 2013 06:24 PM
Boonebird
20
Apr 2, 2008 07:08 PM
csx6025
Aug 17, 2006 09:16 PM
brettmendenhall
Dec 26, 2004 09:25 PM
John8172
Oct 6, 2002 08:05 PM
