6.7 Ford Engine
Old Apr 5, 2009 | 06:35 PM
icrman's Avatar
icrman
6.7 Ford Engine
I hate to rain on the parade, but from the few things I have found out about this new engine, its looking like its going to be more of a problem than the 6.0 and 6.4 put together. It is really a shame that Ford wouldn't look outside the box for some engineering ideas, like they did in the old days. Too much of the cutting the corners deal. Or do these auto companies just do stupid things to purposely goof themselves up financially? Hmmm seems that way. Yeah I could be wrong. Lets wait and see. If it is made like the one article said, then I predict there is going to be a rash of expensive repairs down the road. Hope I'm wrong.
Old Apr 6, 2009 | 01:35 AM
rollerstud98's Avatar
rollerstud98
Don't think you are raining on anybodies parade, you quote no sources so everything you say, just like everything read in magazines with no actual evidence to back anything up is just hear say. That will always happen though. Oh and I always take threads like this one as coming from people who can't afford to buy the new truck but actually wish they could do so when it comes out.
Old Apr 7, 2009 | 02:15 AM
icrman's Avatar
icrman
Quote sources? It is any source that has detailed information on the construction of the engine.
It has nothing to do with can't afford to buy.
Engines are my passion. I'm just disapointed when I see them doing things they should not do on a supposed heavy duty diesel engine. Lets just wait and see what happens. Then we can revive this.
Old Apr 9, 2009 | 09:50 PM
bluextc's Avatar
bluextc
What makes Ford think they can build a diesel engine when they can't repair the ones they already use. Good luck they will need it.
Old Apr 10, 2009 | 08:07 AM
Lead Head's Avatar
Lead Head
They can fix the 6.0s just fine. It just doesn't help that they have to replace the parts that just failed with the same ones. Blame international for that. Some dealers will install headstuds under warranty, and most of the problems go away.
Old Apr 11, 2009 | 11:46 PM
mnmwhit's Avatar
mnmwhit
Sounds to me like someone just wants to argue and complain.
Old Apr 12, 2009 | 02:16 AM
icrman's Avatar
icrman
Not my intention, I just wanted to be psychic and predict. Time will tell.
Old Apr 12, 2009 | 09:00 PM
a-rod's Avatar
a-rod
I think it will be good, I think it has to be if ford wants to stay in the game, my only problem is with the place its being built....
Old Apr 12, 2009 | 09:35 PM
Louisville Joe's Avatar
Louisville Joe
I think I know where icrman is coming from. I have been working on all kinds of diesels for years, and as time goes on, they are getting far more troublesome, less economical, and far more expensive. They don't last as long as they did (thank EGR and low lubricity fuel). You really can't justify a diesel in a pickup anymore. 2010 is going to be worse with urea injection and SRC catalysts. 600 ft. lbs. is meaningless if it is torque managed and the driveline can't take it. Aftermarket mods and programmers void the warranty. I am thinking gas for my next truck.
Old Apr 13, 2009 | 06:28 PM
origcharger's Avatar
origcharger
Do you have any specific examples of Diesel engines not lasting as long because of EGR and low lubricity fuel? Or any specific examples of ULSD being too low in lubricity?
Old Apr 13, 2009 | 07:10 PM
Louisville Joe
In California, we have seen a significant reduction in lubricity long before ULSD. When the low lubricity fuel was introduced, we saw a lot of injection pump failures in older diesels. Seems a lot were Stanadyne distributor style pumps as used on 6.5L GM diesels and International V-8's. Those pump problems were addressed with improved replacement pumps, but I wonder what affect it is having on internal engine parts. I was noticing higher oil consumption in many units around the same tme. After EGR was introduced, even higher oil consumption. My EGR engines don't have that many miles on them yet. I should do oil anlysis on them. I am hearing from other fleets of fewer miles between in-frame overhauls.
Old Apr 15, 2009 | 09:29 PM
greggara's Avatar
greggara
I thought the 6.7 was a simple pushrod with post combustion urea injection whereas the 6.4 uses regen spraying fuel on the exhaust stroke.
If this is the case wouldn't the 6.7 technically be more simple than the 6.4 engine for engine?
Old Apr 15, 2009 | 10:33 PM
Lead Head's Avatar
Lead Head
The 6.7 is no simpler then the 6.4. Maybe in the fact that it is single turbo vs. the 6.4's sequential. Both are 32 valve push rod engines.
Urea injected has nothing to do with DPF regeneration. They are both part of the emissions system but do entirely different tasks.
A 6.4 has a DPF, a 6.7 will have a DPF and an SCR NOx catalyst. The 6.7 will still have the added injector pulse to increase EGTs, as well as the urea injection system infront of the NOx catalyst.
The DPF filters soot, the SCR/NOx catalyst reduced NOx emissions.
Old Apr 15, 2009 | 10:59 PM
greggara's Avatar
greggara
Ok but the fact that the 6.7 doesn't have regen on the exhaust stroke isn't more simple as far as the engine is concerned?
Old Apr 15, 2009 | 11:36 PM
Lead Head's Avatar
Lead Head
The 6.7 still has the injector pulse on the exhaust stroke...It still has a DPF that needs to be regenerated...
