Ae new user ???
Old Apr 5, 2009 | 04:56 PM
O2BNMUDD's Avatar
O2BNMUDD
Ae new user ???
jUST PLUGGED INTO MY 7.3 TO look for any codes. I hit the the button for diagnostic trouble codes and it said 7.3 not compliant due a test onboard system when I did that I had a drop down box with only one option evaporation or something test ..did that but I see no codes ..where do I pull codes using this?? Note that I do not have a check engine light on currently..
Old Apr 5, 2009 | 05:04 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Give me a call, I will walk you through it
Old Apr 5, 2009 | 05:06 PM
F350-6's Avatar
F350-6
Usually the codes show up when you plug it in. It asks if you want all or current codes. Did you go through the connect screen and select the make & engine of your truck? Make sure the drop down box in the connect screen says enhanced power train?
Old Apr 5, 2009 | 05:09 PM
PaysonPSD's Avatar
PaysonPSD
Reps to you Clay.
Old Apr 5, 2009 | 08:25 PM
O2BNMUDD's Avatar
O2BNMUDD
Thanks Clay good customer service ..I installed it on my home computer then to the laptop but I did not have it activated on the lap top..The user guide is not much help. Thanks again
