Drive line angles
Old Apr 5, 2009 | 01:14 PM
david53ford's Avatar
david53ford
Drive line angles
Hi getting ready to weld my axle to spring saddles on do these angle look ok
1 trans @ 1/2 degrees down
2 pinion @ 2 degrees up
3 drive shaft @ 4 degrees
That give me trans to drive shaft 6 1/2 degrees and pinion to drive shaft @ 6 degrees are these number ok?????? Thanks
Old Apr 5, 2009 | 01:42 PM
gdgerland's Avatar
gdgerland
Take a look at this, maybe it will help.
http//www.clubfte.com/users/jiolon/drivelinephasing/drivelinephasing.html
That's the only I can figure out how to post a link.
Hope this helps.
Gil
Old Apr 5, 2009 | 01:58 PM
3golfjack's Avatar
3golfjack
Hope this helps.
Gil
Man thats a greal link. First time I've seen it.
http://www.clubfte.com/users/jniolon...nephasing.html
Old Apr 5, 2009 | 02:00 PM
LEckart's Avatar
LEckart
Yes, the pinion angle up should equal or be close to the trans angle down and you have accomplished that. The centerline of those angles should be parallel or very close.
smoky_diesel
6.7L Power Stroke Diesel
34
May 27, 2014 11:47 PM
rodneywar
16
Jun 28, 2013 07:49 PM
dave91gt
Jun 22, 2009 09:47 AM
2losteve
40
May 22, 2009 12:09 AM
Rposton1
Mar 29, 2005 09:26 AM
