can't read engine codes
Old Apr 5, 2009 | 08:21 AM
arkredneck's Avatar
arkredneck
ok so my check engine light has been coming on ever since it started getting warm. and it only comes on during start up and the truck starts surging kinda like a gasser with a cam then after a few secs it lvls out. then it idles with a miss you can drive it for 5 miles kill it and turn it back on and no light and it runs better. but anyways i took it to advance auto a week ago and the guy said the light had to be on for him to check it. so i took it back yesterday with the light on and his scanner can't read the rodes went to autozone to and they can't read the codes. any idea on whats my problem or how to read the codes???
Old Apr 5, 2009 | 08:41 AM
Majikdog's Avatar
Majikdog
Had same problem reading codes, they told me it was the module where u plug in the reader. Haven't figured out how to fix module. Ford also told me the same thing about bad module. Any suggestions from the ford fanatics would be helpful, beats spending loads of money replacing parts that don't need to be replaced ya.
Old Apr 5, 2009 | 08:43 AM
arkredneck's Avatar
arkredneck
yeah i don't wanna spend money on unbroke parts this truck is already a money pit
Old Apr 5, 2009 | 08:47 AM
F350-6's Avatar
F350-6
The free scans from Autozoo, etc. won't read codes on the 7.3. The engine was designed as a medium duty truck engine, so it's not OBDII compliant.
For the idle issue, have you checked to make sure the engine oil is full? How long since you've changed the oil? If you unplug the ICP sensor, does the funny idle smooth out?
Old Apr 5, 2009 | 09:47 AM
arkredneck's Avatar
arkredneck
yes oil is full and last oil change was almost 3k ago
Old Apr 5, 2009 | 11:39 AM
jboard's Avatar
jboard
arkredneck, that is just about the same symptoms that im having every morning CEL running rough at start, but is fine when it warms if I shut off and start back up. tjbeggs told me to check my UVC im going outside right now to check some stuff out ill let you know if I find anything.
Old Apr 5, 2009 | 12:06 PM
arkredneck's Avatar
arkredneck
its wierd how it goes away when the engine is warm
Old Apr 5, 2009 | 01:05 PM
F350-6's Avatar
F350-6
An electrical connection may expand and seat better when it's warmed up. Also, the IPR or injectors may be having issues with the colder oil.
Old Apr 5, 2009 | 02:49 PM
arkredneck's Avatar
arkredneck
injectors are new can i test the IPR?
Old Apr 5, 2009 | 02:57 PM
F350-6's Avatar
F350-6
New or rebuilt? Sometimes there have been issues with rebuilts. Not much you can do with the IPR other than monitoring duty cycle on a scanner, pulling it out and eyeballing it and changing the o-rings. Sometimes unplugging the ICP sensor will trick the IPR into acting right for a bit.
With that said, how cold is it outside, and what oil are you running? Are you sure you don't just have a case of the romps?
