95 F-150 Saginaw p/s conversion: Bracket problem
1978 Bronco Pressure Hose For Sale
Another Update: Just wanted to update on the P/S pressure hose that I used. I posted that I used the original truck hose, but that was incorrect. The truck pressure hose has a different end compared to the van pressure hose. The van hose requires a 5/16" Male Inv. Flare x 16 mm Male "O" Ring type.
I ordered in a new 1978 Bronco pressure hose thinking it was the one I needed, but it does not fit the van pump (20-7878). It fits the other Saginaw pump that I should have gone with in the first place. I had quite a time tracking down a 1978 Bronco hose up here in Canada. It was on back order for quite awhile. So if anyone is doing the Saginaw swap with new parts, I have a new 1978 Bronco hose from Napa for sale what I paid for it.
What I ended up doing was modifying a van pressure hose. I cut off the excess tubing on the end, bent it 90 degrees, and double flared it to fit. The van pressure hose was off a E-250 351 V8.
So I anyone is in need of a 1978 Bronco pressure hose just send me a message.
Thanks
Thanks
on
Hola Mac
I converted my 67/72 Highboy to the Saginaw (canned ham style) p/s pump, but have been unable to locate the Van style bracket for my 300 I/l 6... I hade to make a bracket, which works for now, but would love to find the factory bracket. Any ideas as to where I can look?
Thanks amigo,
Baja
Thanks amigo,
Baja
TexasGuy001
36
08-29-2022 10:24 AM
Krisverde
26
01-30-2018 08:33 PM
Branded
Ford Truck Parts for Sale
01-21-2017 02:43 PM
evan.kelly978
10-07-2012 06:41 PM
dyingtolive
17
12-08-2011 04:37 AM
