Saginaw P/S Pump Conversion
So I went to the junk yard the week before last and grabbed a power steering pump. The one I have is leaking badly, and the one I grabbed looked almost brand new. So, I sat there thinking about it, and I remembered seeing something about the Saginaw conversion on here, and after reading about the differences between the two pumps, I figured I might as well give it a shot. Seems to me that all I need is the pump, bracket, and hoses off of an 80-86 E-Series van, preferably with the 300I6 (so that the bracket fits on my engine.)
Now, I couldn't really find much information on the conversion. Maybe I was looking in the wrong places, or wasn't looking hard enough, but it seems to me that, with those parts (pump, bracket, hoses), it would be a plug and play kind of procedure. Am I correct in thinking this? Or would I need more parts? Would there be any kind of custom fabrication that I would need to do?
Thanks, guys!
Thanks, guys!
Awesome. I just wanted to make sure I knew what I had to do and had everything squared away before I attempted the conversion. I'm gonna try to make it up to the junk yard tomorrow and exchange the pump I pulled a couple of weeks ago for a Saginaw pump. I'll post pictures and a write up when I actually get a chance to do the conversion.
After working on this thing all day, I have found that this is not a plug and play kinda swap. Not for the 300 I6, anyway. I don't know, maybe I didn't get all of the parts that I needed. But, the bracket on the Saginaw pump doesn't match up to the mounting bracket on the engine. The return line isn't long enough by itself to fit on the Saginaw pump, and the high-pressure hose rubs on the bottom of the power steering belt, although I could probably re-route that and it would be alright. I tried taking the bracket off of the stock pump and putting it on the Saginaw, and only one of the holes matched up, plus the bracket doesn't mount flush to the pump, so the pulley isn't straight. Now, if I had a cutting wheel/grinder, I could fix that, but I have neither. I haven't quite given up on it yet, but right now I'm at somewhat of a loss. At some point, I'll get it figured out.
This is on my junk yard wish list also… but I haven’t figured it out yet.
As I have AC on my 4.9 the power steering belt needs to go on the middle V belt position.
If you can post some picture of what you tried to install, it might help me not repeat the same.
Did you take the Power steering bracket off (4.9 van?) the engine block?
Jim
Jim
When I bought my '89 F150 6cyl, the power steering was unbelievably noisy! Very loud whine, fluid was toped up. The truck has sat for a number of years and only had 54,000 original miles when I bought it. After driving it over 5k miles, whining has slowlly faided away, now doesn't make a sound at all.
And interestingly enough, the pump that I found wasn't mounted to the engine at all. Yes, it did still have the bracket on it and the hoses hooked up, but it was laying on top of the front axle. Unfortunately, I couldn't find anywhere on the engine block that it looked like the bracket on the pump would mount to, perhaps the person that left the pump laying there took that bracket off the engine. And that was the only van on the lot with a carbed 300 I6 with v-belts. The other one had a 351W, I think, which I might go check out tomorrow, and the rest were fuel injected and had a serpentine system.
I just did my saginaw swap today. It took a couple of hours due to my methods of things and that im in a small town in the middle of nowhere. I found an old saginaw pump from an econoline van easy as could be to replace my f150 oem pump. Just unbolted the old one and bolted on the new one with new brackets that came with it. Had to get a new e150 high pressure line but the return line on the f150 worked great. No more wining from my truck. Project was no more than $50 bucks and shouldnt take more than an hour if you have all the parts handy.
