Sponsored by: Real Truck
idle, but no throttle
Old Apr 4, 2009 | 05:26 PM
GTALLMAN1's Avatar
GTALLMAN1
Question idle, but no throttle
I have a 2004 Ford F-250 6.0 Superduty, It will crank up and idle. as soon as you try to throttle up, it cuts off always at 1000rpm, Has anyone ever heard about this? It did this one time before and resolved itself. now it isn't.
Old Apr 5, 2009 | 01:44 PM
acw592's Avatar
acw592
Sounds like a throttle position sensor. I was told that on my 7.3 there is not an actual throttle cable from the pedal, but a wire and when the TPS goes out it will only idle. Not sure if its the same on the 6.0 but it sounds like it.
Old Apr 5, 2009 | 04:01 PM
87 F-150 I6's Avatar
87 F-150 I6
You have a bad TPS(Throttle Position Sensor), you can get just the sensor and related items to fix it or you can get a howl new pedal assembly. I would try FTE parts guy for prices and parts.
Old Apr 6, 2009 | 11:50 AM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
ID NAV #1846544C9* = Fords part number 4C3Z9B989A
ID NAV #1846546C9* = Fords part number 4C4Z9B989B
but it looks cheeper to just get the whole pedal assy
need vin to be sure.
Ed
rhino25
May 21, 2015 08:14 AM
Eric Kropp
Jan 6, 2015 01:05 PM
D_pickup_55
Aug 8, 2014 05:58 PM
1975FordF250
Jun 24, 2014 09:06 PM
MikeKrock
Mar 1, 2011 08:36 PM
