Havent installed mine yet, maybe next weekend. I just measured the right(pass.) side header from the cat flange face to the center of the rear header tube. Its approx 20 1/2" . Crawled under my truck (2000 excur. w/auto trans) and measured from cat flange to last exhaust port and it looks pretty darn close. The cat flange on mine is almost dead center of the trans pan. Hope this helps
I think that because you have a 99, the cat flange is behind the crossmember. My 03 has the cat flange in front of the crossmember so they bolted right up. You might have to make up a pipe to connect them.
Well that sucks... Now I gotta ask since I always considered it being a possibility... Will I be hurting anything if I just decide to cut out the cat and make a pipe from behind the cat to the flange of the header?
Beyond the aforementioned legal and social irresponsibility issues....
Yeah, it will stink (those of us who drove pre-cat cars/trucks know what I'm talking about....) and produce several times more noxious/hazardous emissions. May lower fuel economy. I believe it will also cause the CEL to stay lit up as the downstream O2 sensor will be seeing readings way out of whack.
Headers are on! Exhaust at idle is definitely quieter. Inside the cab it sounds like a rice burner. Outside on the throttle definitely seems louder. Seems like I'm getting better pedal feel and that power has been shifted throughout the RPMs instead of just higher. I did leave the cat on and I do have to take it back because the business I had put a pipe in to connect the header flange to the cat put in a bent *** crimped up POS pipe that looks like its more restrictive than the original y pipe. Overall I don't know if I'm completely happy about this mod but I am definitely glad to have finally gotten rid of that nasty manifold leak.
Next up is the 5 Star Tune and a Livewire Tuner from Mike. Hopefully I can get on that extremely soon and take full advantage of all my mods.
Originally Posted by dkf
I wouldn't advise removing the cat for legal and inspection reasons. If anything remove the stock cat and put in a smaller aftermarket cat.
We don't have inspections here in Indiana. I understand the legal part of it but I was just curious if I was hurting anything by leaving it on or removing it. I've known for awhile that the stock exhaust was pretty decent as far as cat to tailpipe just the y pipe was pretty bad.
About? The header being too short? No. I didn't figure they made a header specifically for the 99 that was longer. Although my mechanic did want me to contact them and tell them to change their bolts up a little bit lol. He said they were some of the worst exhaust bolts he's ever worked with lol.
Yeah just wondering if they new about it being short for the early models and offered a pipe. Not sure what you mean about the bolts. The guy that did my install said some of the bolt holes were off a little. On one hole he had to use an allen head because the hex wouldn't clear the pipe.
Maybe I'll try calling them tomorrow. He told me that the bolts seemed pretty low quality like some chinese stuff and that they should have made them 11mm instead of 12mm. Just little stuff that may have made the job easier.
I'm shure Thorley is aware of the issues with the 99' Y. If I remember correctly Mizzitch (spelled wrong I think) installed thorleys on his 99' and ran into the issue with the y and a filler pipe had to be made.
My 04' has no egr and no O2 sensor after the cat. If you have an O2 after the cat removing the cat will set off the CEL. The rear O2 can be turned off with a tuner. I would just install and aftermarket "performance" cat rather than having no cat at all.
Well... I took my truck somewhere else to have the filler pipe re-done since the shop that did it yesterday put un necessary bends in it and had it all crimped/pinched to hell. That shop will be seeing me soon with that POS pipe in hand demanding a refund.
Anyone else's sound like a damned import car inside the cab? I mean I understand why it would based on the way the motor works but it didn't before... why would it now?
I did leave the cat alone for the time being. I don't have an O2 after the cat so it wouldn't have been a big thing. Next up is a tuner hopefully next month or the month after.
Mine sounds like a transit bus powered by CNG. I don't mind it at all. Not sure what it sounds like at the muffler. Haven't been by a sound wall at hard throttle yet.
