steering confusing
Old Apr 4, 2009 | 07:19 AM
dragonmaster093's Avatar
dragonmaster093
Thumbs down steering confusing
hey guys help my power steering hoses go from pump to a peice on the of the frame then i have what looks like a stabilizer but has lines coming out
Old Apr 4, 2009 | 11:50 AM
75F350's Avatar
75F350
What is the question???
Are you asking what the stabilizer thing is? This is the hydraulic ram that makes up the hydraulic assist steering.
Have to assume that the vehicle in question is the highboy in your avitar, it is safe to say that you are looking at a factory hydraulic asist system.
Old Apr 4, 2009 | 03:00 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Power Assist P/S
The pressure and return hoses feed from the P/S pump to the P/S Control Valve.
Two additional short P/S hoses feed from the Control Valve to the Ram Cylinder.
The steering gearbox has nothing to do with Power Assist P/S, so there are no hoses connected to it.
Two completely different types of Power Assist P/S were used on High Boys.
All 1973's, 1974's before serial number T80,001 use Garrison P/S.
1974's after serial number T80,001, 1975/76's and 1977's before serial number Y20,001 use Bendix P/S.
No parts interchange between these two P/S systems.
Old Apr 5, 2009 | 09:39 PM
dragonmaster093
i was csurious because didnt see the part in lmc next question is what can i do to fix the play between the steering wheel and the steering box can turn wheel back and forth shaft turns all the way to box
Old Apr 6, 2009 | 03:48 AM
NumberDummy
I'm assuming your truck has 4WD, but...
What year is the truck? Is it an F100, F150 or F250?
If it's a 1974 F100 or F250, which Power Assist P/S system does it have? See post #3.
What could cause play: Bushings that mount the ram cylinder to the frame. worn tie rods, draglink.
Worn bearings/bushings inside the steering gearbox. Replaceable U-Joint inside the steering column (1973/75 only)..and there's more.
When you ask questions, PLEASE list all the pertinent details.
You seem not to know what parts need replacing, so...I suggest you take the truck to a front end shop and ask for a diagnosis.
Old Apr 7, 2009 | 09:23 AM
dragonmaster093
1976 f250 4x4 looked at ball joints ect all seem tight only play can turn wheel back and forth shaft turns back and forth no movment any where else till you get to the end of play
