No back up lights??
Old Apr 4, 2009 | 12:22 AM
alconk's Avatar
alconk
No back up lights??
This is driving me crazy... When I bought the truck the backup lights didn't work, I replaced the bulbs and sockets still nothing. So I think it's the neutral saftey switch so I buy a new one and install it. They worked for about a two weeks then back to nothing. This is tied in with the wipers and they work so I know it's not a fuse. I go down and look at the NSS and it's a little oily from the tranny so I figure somehow it shorted the switch. I take it back and have it warranted out and get another new one and installed it just a little bit ago and nothing. Where do I go from here?? I want them to work like they should
Old Apr 4, 2009 | 01:46 AM
fmc400's Avatar
fmc400
MSEE
With the truck off, turn the key to run, and have a buddy stand behind the truck watching the lights while you run through all the gears. There might be some slack which only makes them come on between park and reverse, etc. You might want to check the new switch with your multimeter set to continuity, or resistance if you don't have that. Then you can check the functionality of the switch. It's a pretty common problem for these switches to fail because of leaking ATF and other engine grime.
Old Apr 4, 2009 | 02:17 AM
alconk's Avatar
alconk
Well I did what you just said but with a mirror, not even a nano-second of light while going through the gears.
Old Apr 4, 2009 | 02:24 AM
fmc400's Avatar
fmc400
MSEE
In that case, you'll just have to start at the source and work your way down the circuit with your meter until the power cuts out. First check for voltage at the switch, then check the switch for continuity. It's cutting out somewhere, unfortunately the only real way to pinpoint it is to check the whole circuit. Deducing that the fuse is good by observing that the windshield wipers work is about the only shortcut you can take. That is, unless someone has hacked up the original wiring, in which case it's anybody's guess.
Old Apr 5, 2009 | 01:17 PM
460Brnc's Avatar
460Brnc
Bad grounds at the sockets can keep you back up lights from working. Remove the socket and take out the bulb. With the key to the "ON" position and the transmission in reverse, you should find 12 VDC at the center contact in the socket. If you do, then its a bad ground at the socket. If you don't find 12 VDC, then you problem is further up the wiring.
You can also check for continuity between the side of the socket and chassis ground.
The backup lights on my Supercab didn't work when I got it. I first found a blown fuse, then the NSS was bad, a bulb was bad and finally a socket was bad. I now have backup lights but it was a lot of work.
Good Luck!
Old Apr 5, 2009 | 01:32 PM
unrulee's Avatar
unrulee
Are you sure? My 79 f250 isn't. The washer pump is tied to the reverse lights but not the wiper motor.
Old Apr 5, 2009 | 07:13 PM
78Ranger_GARedNeck's Avatar
78Ranger_GARedNeck
as of last month mine dont work either, but they did..Iknow the bulbs are good and all tho because my trailor wiring is jacked up. When i had a combo of brake, turnsignal and and/or runnin lites the reverse lights flashed with the turn sigs. . so the bulbs are capable of lighting up and the fuses are good also. How much is tha NSS?
Old Apr 5, 2009 | 07:42 PM
fmc400's Avatar
fmc400
MSEE
Bingo! The wiper washer uses the same fuse as the backup lights, but the wiper motor itself uses a circuit breaker integrated into the wiper switch. I just checked my 79's manual. Great catch.
Old Apr 5, 2009 | 08:30 PM
alconk's Avatar
alconk
Both my washers and wipers work... Where is the circut breaker? I looked for one at the fuse bos and don't see any just the glass fuses???
Old Apr 5, 2009 | 08:34 PM
alconk's Avatar
alconk
Never mind on that last question about the circut breaker..(intergrated in switch) I read too fast sometimes...
80ford100
Feb 11, 2015 09:16 AM
JonDavis1984
Jan 10, 2014 09:45 PM
pin8246
Jun 3, 2013 02:01 AM
greennwhite 77
Feb 7, 2010 07:13 PM
THE KING
Dec 27, 2006 03:38 PM
