Coil Problem.Need help.
And ignition switch?Great.Is there any way I can test it to see if it's worn out?And if it's misadjusted,is there any way that I can readjust it?Thanks for the help.
It's basicly a eye connection where a bolt goes through. Simular to the one on the starter solenoid. Difference is the insulation is cut around the cable, and the eye connection is crimped around the cable leaving a place where you can bolt it to the frame.
Checking the ignition switch, check movement of the lock cylinder, and rod, is it nice and smooth, or does it bind? Is there any resistance trying to turn the switch to the start position? There should be some resistance from the spring in the ignition switch, but not so much as to make it hard to turn. Also does the switch spring back to the run position like it should, or do you have to move the switch back to the run position to get the radio and turn signals to work?
As for adjusting the ignition switch, you have to lower the column to reach it. Loosen the attaching screws and slightly move it lower or higher on the column relative to the lock cylinder rod. It may be wise to just get a replacement ignition switch at the same time. And instructions come with some ignition switches.
Oh okay I get it.
As far as the ignition switch,the lock cylinder and rod work very smoothly,and there is no binding.There is no resistance aside from the resistance by the spring.It isn't hard to turn the key either.The switch springs back,but i've never tried to see if it goes all the way back to run.I'll try that later today and post the results.I'm out at a buddy's house right now workin on his truck,so when I get home i'll check it and get back to ya.Thanks for all the help.
