Proportioning valve
Old Apr 7, 2009 | 04:14 PM
mhopkins's Avatar
mhopkins
Cold in Buffalo today so I haven't worked on the prop. valve, just taking in all the great input from Bigred, F.Hagen and all the others. Since I discovered the parking brake is locked up I decided to pull the brake drums and have a look. Wow, you have to pull the axle on the HD F-250 and of course the drum won't release even with the star wheel backed off as far as I can get it. What a pain, anybody got a torch!!
Old Apr 7, 2009 | 07:28 PM
86F250BIGBLOCK's Avatar
86F250BIGBLOCK
the drums should just slide off if its a sterling 10.25 without pulling the axles. my 86 f250 hd has the sterling. I thought all heavy duty's did? The Dana 60's needed the axles pulled. Also about the rear prop. valve, when i lifted my truck i never messed with it. It still seems to work fine, and apparently it can compensate for a small difference in frame/axle height.
Old Apr 9, 2009 | 07:42 AM
mhopkins's Avatar
mhopkins
Wink
Not seeing anything on the sterling axle, my cover is a 12 bolt pattern in a pear shape. Based on what I can find, it is a Ford 10.25 full floating axle which Chiltions says to pull the axel shaft. Hindsight, I agree with you on drum removal. The prop. valve will have to wait until I get a look at the brakes. Thanks for your input.
Old Apr 9, 2009 | 07:54 PM
bashby's Avatar
bashby
ford/sterling 10.25 is the same axle
Supercab
Mar 5, 2024 09:48 PM
high6
Sep 6, 2016 01:23 AM
JEDWIN
Feb 22, 2012 03:46 PM
mdr617
17
Oct 21, 2010 05:24 PM
classicranger
Nov 30, 2008 12:50 PM
