Aussie heads worth it?
Old Apr 3, 2009 | 03:46 PM
kettle-one's Avatar
kettle-one
So, I'm pondering my 400 build. I have a complete 79 400 to rebuild for my 79' short wide 4x4, 4 speed pickup. I do not tow, race, or haul anything heavy. basically I'd like a motor with a little fun factor and not spin it past 5500 rpms, so I'm thinking of;
TMI pistons
ComCams Hydraulic roller COMP Cams - Cam Details
Scorpion bolt down rockers
balanced rotating assembly
Recurve distributor for my build and rig
and already have on my 351m
Edelbrock Performer non-egr intake
Holley 600cfm
Hedman 1-5/8" fender well headers
2-1/2" exhaust with Magnaflow cats and Flowmasters
Which leaves my question about what heads to run. Looking at others builds and available parts, I have tossed around using the Aussie heads, but are they worth it for my level of build? I know they have better combustion chambers, but are the stock open chambers as good with the better TMI pistons? I know the exhaust port of the Aussie is better than the later 2v due to the cooling hump. I guess at what point do you toss the 2v's and go Aussie?
I'm not including Alloy heads, those are way out of my budget.
Old Apr 3, 2009 | 04:02 PM
dragon-squire's Avatar
dragon-squire
the money you spend on the Aussie heads you can just clean up the stockers and have a little left to put someplace else. they'll work just fine for your build.......a little clean up and a good valve job and there you go....money in the bank and the fun factor is still there.
Old Apr 3, 2009 | 04:04 PM
kettle-one's Avatar
kettle-one
^^ Those are my thoughts as well, I'd rather not spend money if I don't have too.
Old Apr 3, 2009 | 04:43 PM
dragon-squire
I've just built my 400 a little on the extreeme side but still inexpensively.....check it out thread is new here built my 400 there are pics there as well
Old Apr 3, 2009 | 08:28 PM
hollenjoe's Avatar
hollenjoe
TMI pistons
Holley 600cfm
Hi man,
yeah you can use your stock heads and they will do fine, instead i suggest:
1. getting for 150 bucks more some yella terra bolt down adjustable rocker arms (tim sells them), since with them you dont need machining nosr guide plates to have adjustable rockers and will have a more acurate lift than with the scropions (just ordered ones myself)
2.If keeping the stock 2v heads i recomend for 30 bucks more (i think) getting a costum roller grind from comp cams (tim also knows) and extend the exhaust duration from seat to seat a bit more, expample: the magnum you want has 270 int 270 ext, make it 270 int 280 ext, believe me you will benefit a LOT more and will have sooner and way better torque... since the 2v exaust port on this heads are a bit limmited a double profile cam is recomended...
Old Apr 6, 2009 | 10:37 AM
kettle-one's Avatar
kettle-one
^^ good points. So the Yella Terra's don't require guide plates?
Old Apr 6, 2009 | 02:07 PM
hollenjoe's Avatar
hollenjoe
nope, they are just bolt on, nothing required, I just ordered a set myself..
Old Apr 7, 2009 | 06:08 PM
JBradley500's Avatar
JBradley500
i wouldnt buy aussie heads unless i ran a flat top piston rule racing class with stock heads... i bought 2 sets and both were cracked. if you want to spend money on heads, buy aluminum with the machine work already done and you will be money and power ahead, and if you dont want to spend money just use stock and you will be fine.
caspermj
Jan 12, 2012 03:20 PM
ErrorS
Feb 15, 2008 05:55 AM
roger dowty
13
Nov 4, 2006 05:11 PM
78bigbronco
Jul 31, 2006 08:33 AM
packlet
Dec 20, 2004 03:39 PM
