Modular V10 (6.8l)
Exhaust Header
Old Apr 3, 2009 | 08:21 AM
kmhendress's Avatar
kmhendress
Exhaust Header
I'm thinking about changing the exhaust manifold on my 99 V10 F250 SD. Right now it has the OEM exhaust manifold.
I found an Exhaust Header on eBay that is stainless steel for like $100, much cheaper than the others. Wondering if anyone has any experience with those?
eBay Motors: Ford V10 Headers 99 00 01 02 03 04 STAINLESS F250 F350 (item 110371868799 end time Apr-08-09 16:50:37 PDT)
Part Brand:Top Speed Pro 1
Thanks,
Kevin
Old Apr 3, 2009 | 11:04 AM
dkf's Avatar
dkf
https://www.ford-trucks.com/forums/5...ud-or-two.html
Old Apr 6, 2009 | 03:40 PM
eightrac's Avatar
eightrac
I have them. They've served me very well so far (1yr-8mo.). Just remember that they do require some modification to the passenger side frame rail (easily cured with a cutting wheel on an angle grinder) and that if you have egr that they will require a egr bung welded into one of the primaries -OR- your egr system disabled capped/removed by use of a tuner if you live in an inspection area, you'll only be able to have the bung welded in.
Within minutes of the first run they went from chrome to orange to blue and mine are now showing some "weathering" after the time I've had them. They are still very much intact and look quite good over the time they've been installed.
