tire size questions
Old Apr 3, 2009 | 02:44 AM
GwarForAll1021's Avatar
GwarForAll1021
tire size questions
i dont know much about tires so im asking you
will a Baja Claw Radial Tire 33'' x 15.5''R - 18'' fit on a stock 18" fx4 rim?
15.5 sounds afully wide ... crazy wide actually but i thought id ask first
Old Apr 3, 2009 | 03:24 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
not at all man
1. too wide for safely mounting...if you could even make it work on a 7.5" rim
2. a 12.5" is the absolute max you can fit on OEM rims and not rub anything...period
3. you will need aftermarket rims that are at least 10" wide IMO and a hell of alot of backspacing/offset. most likely end up with almost 1/2 the tire sitting outside the wheelwell
Old Apr 3, 2009 | 04:39 AM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
I agree with tylus I definetly wouldnt go any wider than a 12.5 on a stock wheel
Old Apr 3, 2009 | 03:50 PM
GwarForAll1021
yea only reason i asked cuz i found a set of thouse with the tape still on them full set for 400 bucks
great deal but now i know why.
nobody can use them
thanks guys
Old Apr 3, 2009 | 04:39 PM
GwarForAll1021
haha im really loving how i cant find the tires i want in 12.5 for 18 inch rims
there all 13.5 or i have to buy 17's
