Die's after start up
Old Apr 2, 2009 | 09:53 PM
Dirtboy953b's Avatar
Dirtboy953b
Hello, I have oth a 86' 6.9 and a 89' 7.3,and when they are cold about 3-4 seconds after start up they die and are hard to start back up,if you give them about 1/4-1/2 trottle they will not die.....any help??
Old Apr 3, 2009 | 12:22 AM
Wookie35's Avatar
Wookie35
Sounds like your cold start enrichment system is not working properly. Pop the hood, have a friend turn the key on and then press the pedal down about 1/4 - 1/3 and release. You should see a small cylinder on the left side( as you are looking at it) of the IP. This cylinder should push out when the pedal is pressed down with the key on and cold start. If it does not do this then that would be a good thing to look at first.
Old Apr 3, 2009 | 12:30 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Air intrusion.
-Enjoy
fh : )_~
Old Apr 3, 2009 | 12:35 AM
starmilt's Avatar
starmilt
You have a classic air leak most likely place is your returnline T's.
wes2k3
20
Aug 6, 2013 10:30 PM
Dozer99
47
Dec 11, 2010 07:05 AM
00RANGER/76F250
Mar 26, 2008 10:40 AM
hwkeye27
May 5, 2005 02:25 AM
evil tim
Feb 9, 2005 09:50 PM
