Heater core??
Old Apr 2, 2009 | 08:53 PM
blue64's Avatar
blue64
Heater core??
I am looking for a new heater core for my 64 f100. I have went to all local parts stores and no luck. I was told I would most likely run into this problem. They can get a core for a 66-72, is this the same or not? Does anybody know of a website or somewhere I could get one? Any help is appreciated.
Thanks!
Old Apr 2, 2009 | 09:11 PM
camperspecial65's Avatar
camperspecial65
theres 2 places that have one NOS...genuine FoMoCo piece...
its part number is C2TZ18476A
Its application is 1964 F100/250 , 1965-9 N1000 or 1965-9 NT 850/950(NH diesel)
The places are Don Sanderson Ford in Az, 623-842-8762
Antique Auto Supply in Tx, 817-275-2381
They each have one...another thing to try is to call a local place and ask using the N or NT truck series application info. It seems to me most parts places go back to 1966...I have that problem hunting for stuff for my 65...
- cs65
Old Apr 3, 2009 | 05:19 AM
jowilker's Avatar
jowilker
blue, I would recommend that you get a plastic hose coupling or a 3" piece of copper water pipe, that is about 5/8" OD, pull your heater hose off the core, place the coupling in the two ends and clamp it to make a loop. Pull the heater core and take it with you to the parts house and get it matched up. With the loop in the heater lines you can drive the truck while you shop if you need to without worry about harming anything. You wont have heat in the cab, but you can use the truck.
Sometimes it is easier to try that method than argue with counter peeps.
John :-x06
Old Apr 3, 2009 | 05:35 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Its application is 1964 F100/250, 1965-9 N1000 or 1965-9 NT 850/950 (NH diesel).
What parts catalog are you getting these applications from?
C2TZ18476A .. Heater Core / Use with Fresh Air or Recirculating Heater / Obsolete
Fits: 1961/64 F100/1100 / 1961/64 N/NT/T500/1000 / 1965/69 N1000 / 1965/69 NT850/950 NH Diesel.
Personally...I'd do what John recommended, take the old core to NAPA or a good indie autoparts store and match the puppy up.
Old Apr 3, 2009 | 10:49 AM
blue64's Avatar
blue64
Ok thanks. I have already done that with the hoses for that same reaseon to be able to drive it. I will do some more checking. Thanks for the help.
Gamc
Oct 19, 2016 01:37 PM
CSmalley64
Nov 18, 2015 08:06 AM
JasonBrod
1997 - 2003 F150
Oct 4, 2012 02:05 PM
f150rd
Dec 19, 2011 07:55 AM
dohc_chump
27
Sep 28, 2010 03:04 PM
