Sponsored by: Real Truck
Converter lockup question
Old Apr 2, 2009 | 06:18 PM
Ubbzy's Avatar
Ubbzy
05 CC v10 5R110W
At what point during normal acceleration does the converter lock up? I can only count 5 shift points (RPM Drops). Does it lock during a shift?
Old Apr 2, 2009 | 06:27 PM
senix's Avatar
senix
on my 08 it locks at 50 mph. But maybe the is because of the desiel.
Old Apr 2, 2009 | 06:58 PM
5 Star Tuning's Avatar
5 Star Tuning
Former Vendor
Originally Posted by Ubbzy
05 CC v10 5R110W
Locks in OD aka 5th gear in normal driving in Non Tow/Haul mode. In Tow/Haul mode 3,4,5 gears will lock depending on throttle position and Mph.
Old Apr 2, 2009 | 08:04 PM
jk080's Avatar
jk080
Transmission Rebuilder
05 CC v10 5R110W
If you felt and noticed 5 changes in rpms then you felt the converter at the end of 5th gear.
Remember you started in first, so the first shift you felt was it shifting from 1st to 2nd.
So
1st to 2nd = 1 shift
2nd to 3rd = 2 shifts
3rd to 4th = 3 shifts
4th to 5th = 4 shifts
5th to LU = 5 shifts
Old Apr 3, 2009 | 07:04 PM
Ubbzy's Avatar
Ubbzy
Ok so I checked it again this morning on the way to work. I can only see 4 shifts. I got up to 65mph . Does it have to be at full operating temp or something? How much RPM drop should I see for the TC LU
Old Apr 3, 2009 | 07:09 PM
senix's Avatar
senix
i get about 3-400 rpm drop on tc lockup. did the tranny get warmed up? how far a drive. I suppose if you don't get up operating temp it may not lock up.
Old Apr 3, 2009 | 07:49 PM
5 Star Tuning
Former Vendor
Thats Ford not using all the gears in their shift strategies. There is also a RPM drop before shift scalar thats normally set to 400-600 in factory form.
Old Apr 3, 2009 | 08:25 PM
Ubbzy's Avatar
Ubbzy
Talk to me about your tuners... How many tunes do I get in one tuner.....??
Old Apr 3, 2009 | 10:47 PM
995.4SD's Avatar
995.4SD
fordmdb: I am not sure exactly how the lockup works, but im pretty sure I have felt mine lockup in 2nd gear. I was going about 45-55 in second gear and i heard lockup and saw the RPM's drop about 300 right as i floored it. If i don't floor it and just steadily increase throttle there is no indication of lockup. I have heard oversized tires have some affect on it and I am running 35's with 3.73 gearing.
Old Apr 4, 2009 | 06:44 AM
5 Star Tuning
Former Vendor
There are 3 custom tunes on the X3's. See here for a little more info Got a V10 Ford F250/350/450/550?
Old Apr 4, 2009 | 06:49 AM
5 Star Tuning
Former Vendor
Your correct on 4R100 trans depending on throttle postion and Mph, 2nd gear can lock. The OP has the 5R110 Torqshift trans. Both have different lock strategies.
