bad lifters??
Old Apr 2, 2009 | 01:53 PM
bad96's Avatar
bad96
bad lifters??
heres what i have:
79 block .030 over re-build
10.5:1 pistons
dove heads ported to scotty's (Reincarnation)specs
new springs, roller rockers, p-rods, guideplates, valves
34-239-4 comp cam
832-16 lifters---hydraulic
the springs and lifters were the recommended comp cams
the truck has seen about 2k miles(mainly cruisin with a few WOT stabs--but only to 5500 RPMs)
my problem was i went to adjust the valves and its my lifters that are bad(according to a friend that is an excellent engine builder and tuner)
is it possible to get bad lifters???
i was gonna order a new set of the comp cams for the $90 but should i look into a different set or manufacturer that would be better?
thanks in advance!!!
Old Apr 2, 2009 | 04:06 PM
mark a.'s Avatar
mark a.
What are they doing ? Solids, hydros, rollers ?
Old Apr 2, 2009 | 05:04 PM
bad96's Avatar
bad96
i forgot to add its a 460
there not pumpin up (hydraulic lifters) , try to adjust warmed up with no success, then cold and then start it and it just "ticks" like crazy (no change from when warm)---finger tight then 1/4---1/2 turn
there is no clearance issues or any of that stuff either, upper end only has 3-500 miles on it, lower 2000 miles
it was fine when it was first put back together (soaked lifters in oil overnight) so we thought it just needed valve adjustment,
im lookin for some input on what everyone else is thinkin
i heard comp cams had an issue with some of them 1-2 years ago(built outside the US)
thanks again
Old Apr 3, 2009 | 12:01 PM
mcdonaldm's Avatar
mcdonaldm
did hear that a few years ago there was a lot of bad lifters flooding the market as a major lifter manufacturer shut it doors and everyone else was scrambling to fill the void and quality went way down.
another thing with lifters is the break in is very very important that the cam manufacturers breakin procedure is followed exactly. seen a lot of cams and lifter wiped out because of this.
the other problem is that all the major oil manufacturers have reduced or elimanated the zinc in their oils and this by most accounts causes a lot of problem with cam break in and life of the cams. there are a few maufactures out there offering special oils for cam break in (Joe Gibbs for one and i think Royal Purple) so take a look around.
before changing lifters, check the cam lobes to makes sure they weren't damaged also. you might be changing the cam also as usually the bad lifter takes out the cam lobe also.
rgds
Mike
Old Apr 5, 2009 | 09:32 AM
mark a.'s Avatar
mark a.
If it has good oil psi & they are adjusted right then I'd say get a new set. I only get them from Reed. They still had a lot of good USA made ones the last time I bought a set.
Old Apr 8, 2009 | 03:09 AM
wdfp's Avatar
wdfp
You can try setting them at zero lash also, I had a set doing what you describe and set them at zero they calmed down and started working like they should. Just tight enough to not rattle. Its worth a try anyway. Hope it helps!
