Radio not working
Old Apr 2, 2009 | 10:44 AM
ohardy's Avatar
ohardy
Radio not working
Hey guys I have a 2001 F350 I use as a work truck. Yesterday I was out working and I had my door open with the radio on and i couldn't take much more of the door chime going off so I started poking around under the dash and pulled the number 3 relay out from the fuse panel, well the chime stopped working and so did my radio but when i put the relay back in it still wont work. I have checked all my fuses with a voltmeter and none are blown. I also replaced the relay I took out with another one and that didnt work. Any Ideas?
Old Apr 2, 2009 | 12:02 PM
megawatt00's Avatar
megawatt00
Take a look at the socket that the relay plugs into. One of the connections may have come loose.
Old Apr 2, 2009 | 12:53 PM
ohardy's Avatar
ohardy
I looked at the connections and even pushed a spade connector into them just to make sure none of them were loose but they are all tight. This has got me so frustrated.
Old Apr 2, 2009 | 01:33 PM
megawatt00's Avatar
megawatt00
When you plugged the relay in did the chime come back on?
Old Apr 2, 2009 | 01:49 PM
riverrat41's Avatar
riverrat41
You can kill that chime when the key is in the ignition by disconnecting the black/puple wire that plugs into the key switch reciever.Jim probably has a picture but Chris(F350-6) showed me how to get rid of it.
Old Apr 2, 2009 | 04:17 PM
ohardy's Avatar
ohardy
No the chime never came back on thats why I thought it was a fuse but I have tested each and every fuse in the panel and in the distrobution box.
Old Apr 2, 2009 | 04:19 PM
megawatt00's Avatar
megawatt00
I'll take a look at the wiring diagram a little later on to see if anything sticks out. I have them on a PDF on my pc
Old Apr 2, 2009 | 04:20 PM
superduty4x4's Avatar
superduty4x4
Note to self: kill the stupid door chime tomorrow.
