Glow plug issues
Old Apr 2, 2009 | 05:13 AM
cypressknee's Avatar
cypressknee
Glow plug issues
My truck has become hard to crank on cold morning's. I have checked the GPR (was good) and the OHM's of the 2 wires (brown and yellow) going to the plugs. I was wondering if there is any thing else i can check before i pull the valve covers and have to replace 80$ gaskets. I just changed the oil and fuel filter (i was told that the engine oil could affect the injectors) as well as add a can of Lucas injector cleaner to the tank. Thank's Chris for your help, really apriciated it buddy
Old Apr 2, 2009 | 05:20 AM
just another truck's Avatar
just another truck
If your truck is hard to "crank", you are not having a glow plug issue.. If you would, please go back and inspect/clean/tighten your battery connections and get back to us..
By the Way, Welcome to FTE.. hang out, there is a great group of guys here..( and gals )
Old Apr 2, 2009 | 05:34 AM
cypressknee
I forgot to mention that i did that as well (cleaned the connections). The truck spins over good, just spins longer than it supposed to. And thanks this site is way cool i am glad i stumbled on it
Old Apr 2, 2009 | 05:39 AM
just another truck
Dumb question, what is oil your oil level look like, and last time you changed it??
If both of these are Good and Recent, then we might have you check your oil level in the HPOP before you start it.
Old Apr 2, 2009 | 05:47 AM
cypressknee
i check it (enigine oil) at least once a week. I was reading about the HPOP (kinda in front of the FF cover) but i have never checked that. Didn't really know much about it. The engine oil was changed last weekend. I use mobil delvac oil. I am told it's the best
Old Apr 2, 2009 | 05:50 AM
12ozd's Avatar
12ozd
I don't think its very common for VC gasket failures.
More common would be the connections to the VC,and the harnesses under the VC.The VC gaskets are reusable.
How long does the glow plug light stay on?
Check out post # 2 on this thread.
https://www.ford-trucks.com/forums/8...and-relay.html
Old Apr 2, 2009 | 05:53 AM
just another truck
https://www.ford-trucks.com/forums/7...pr-system.html
Only because I dont want to really start chasing our tails here yet, with out you verifying your first thought, The link that I have attached will cover everything that you could think of for your GPR system. Read through this, if it doesnt help you find it, we can go from there.
Old Apr 2, 2009 | 06:17 AM
megawatt00's Avatar
megawatt00
Welcome to FTE. The gaskets are reusable on our trucks. When you say hard to crank what do you mean? Turning over slower than normal? How old are your batteries? What do all the connections look like?
Old Apr 2, 2009 | 06:25 AM
F350-6's Avatar
F350-6
Glad to see you figured out how to get the thread started. Since you've already tested the GPR with a meter, it's time to disconnect the flat connectors on the inboard side of each valve cover and ohm the pins inside the valve cover connector. The link above tells you how to do that. If you have questions or don't follow what's being said, feel free to ask and we'll dig up some pictures for you.
I've pulled the valve covers on several trucks and never had to replace a gasket yet. They're a rubber material that is re-usable, so no worries there.
If you end up needing to pull the valve covers let us know. There's a couple of things you should look at while you're in there. (That won't cost you any more money)
Old Apr 2, 2009 | 08:44 AM
danskool's Avatar
danskool
Go Bills !
Except 50cents.
Old Apr 3, 2009 | 05:26 AM
cypressknee
thanks fella's you guys are a lot of help, i am going to play with some more things this weekend while i have time
Old Apr 5, 2009 | 07:51 PM
cypressknee
hey guys thanks for the help, my father and i changes the gp's on my truck today, was not as bad as i thought it would be. i'll see in the morning if it helps, thanks againg for all the info
tonefordays
Nov 8, 2011 06:32 PM
97 HD
Jul 19, 2007 05:24 AM
wcurtis
Jan 22, 2007 07:41 AM
baseba8311
3.8 & 4.2L V6
Nov 18, 2006 05:07 PM
albcasummit
Oil & Lubrication
34
Nov 14, 2005 01:35 PM
