towing 460 build up
Old Jul 10, 2001 | 10:28 PM
f10074's Avatar
f10074
towing 460 build up
I will begin rebuilding a 460 for my F350 that I tow a 15,000 lb trailer with. I have asked the question before but I am asking again and taking notes this time.
1.) the engine will be out of my 77 f250, my motor guy has some good ideas about what he wants to do but any ideas will be useful
2.) I plan on redoing the electrical side with MSD parts to include and new dizzy, coil, wires, ignition like a MSD 6, and a variable timing ****
3.) I want some headers (what kind and coating) also should I go with a large single or duals?
4.) Fuel pump electric or mech. or both, I looking at running steel braided line prop 3/8 or maybe 1/2
5.) water pump? My water temp does great when I'm not towing but when I do it goes way up any ideas or easy fixes?
6.) any other thoughts or suggestions
William (Tony) Whited
74 F350 Ranger XLT Super Camper Special 460
77 F150 Custom 460
77 F250 Custom 460 (parts truck)
El Paso TX
Semper Fi
Old Jul 11, 2001 | 06:47 AM
DeenHylton's Avatar
DeenHylton
towing 460 build up
I can't even imagine trying to tow 15,000 lb. with a 460...Ford recommends a 4.63 gear for that kind of trailer weight. I'd buy a tubo diesel or stroke your 460 or supercharge it, otherwise you'll be crawling up the hills at 30 MPH in second gear.
2.) I plan on redoing the electrical side with MSD parts to include and new dizzy, coil, wires, ignition like a MSD 6, and a variable timing ****.
You won't be spinning the heck out of this engine, your stock components will be adequate unless they are worn out or unless you go to supercharging.
Go with duals all the way back.
1/2 inch is for racing, stick with a 3/8 line. An aftermarket mechanical pump such as a Holley will flow more than enough fuel.
Your truck is almost 30 years old...I'd replace the radiator with a brand new heavy duty core. Make sure your block is also completely hot-tanked when it's rebuilt. Make sure all the shrouding is in place and use a factory style fan (no "flex-blades"). There is no easy fix on this, just spend the money and do it.
Trade down to a smaller trailer/5th wheel. Try to keep the weight under 11,000-12,000 lbs...even at that weight you should have 4:11 gearing for hill climbing.
77 F150 Custom 460
El Paso TX
Semper Fi
Deen Hylton
Ford F250 460 C-6, K&N, Headers, Dual Exh.,Comp. Cams,Shift Kit
Pioneer CD w/Bose Speakers.
Other Passion: Blown 77 Corvette (Sorry Guys/Gals)
How I can afford to Drive the above: 93 GEO Metro
Old Jul 11, 2001 | 02:08 PM
webguyrich's Avatar
webguyrich
towing 460 build up
I'm glad he lives in TX and I'm in CA, that setup is extremely overloaded. The GCWR for that 350 is only 18,500. The truck itself probably weighs in at 6800 wet but empty. That only leaves you with 11,700 available for trailer, gear, generator, and people. The pin weight on the trailer is probably around 2,800 - 3,000. If I'm correct the GVWR on that rig is 9,500. Add the 6800 and we'll take the low estimate of 2800 pin weight and you end up with a GVWR of 9600...over weight on GVWR and GCWR now!
Ford put's these ratings on these trucks for the safety of the driver, passengers, and the motorists you share the road with. If you were to get into an accident with this rig and they proved you were over weight, you're in deep doo doo. Your insurance company can even drop you without paying a dime for the lawsuit.
Just my legal .02 cents
Rich
Old Jul 11, 2001 | 03:45 PM
f10074's Avatar
f10074
towing 460 build up
Webguyrich
The GVW for my truck is 10,000 lb, it doesn't have a listed GCWR. My trailer doesn't weigh in at 15,000lb I over stated that. It weighs 8,000lb unloaded and loaded about 12,000lb. My trailer is light by today's standards, you ought to see some of things that people are hauling out there. I saw a late 80's Ranger towing a 8,000lb 5th wheel. Talk about scary. My rig is extremely safe and driveable, I had no problems on my 3 week 7,000 mile trip, (which included 4 hours or lovely LA traffic).
77 F150 Custom 460
El Paso TX
Semper Fi
Old Jul 12, 2001 | 08:10 AM
webguyrich's Avatar
webguyrich
towing 460 build up
The main problem is that RV salesman don't care about people's safety, all they want is your money. They'd tell you a hyundai would pull a 30" TT if it got you to buy it.
Old Jul 12, 2001 | 12:06 PM
hpguy's Avatar
hpguy
towing 460 build up
army350
6.7L Power Stroke Diesel
28
Mar 21, 2026 12:57 PM
wrd0225
Jul 28, 2016 09:14 PM
wrd0225
Jun 11, 2016 02:24 PM
RL250
163
Apr 7, 2015 05:51 PM
6strings
May 14, 2014 07:06 PM
