Sponsored by: Innova
cb install help
Old Apr 1, 2009 | 07:30 PM
9900imatt's Avatar
9900imatt
cb install help
hey guys, thanks in advance, i have an 06 f-250 and i', looking to install a cobra 29 cb in it, i'm not sure where to mount the cb in the cab, i'm thinking to the right of the accelerator pedal, right below the upfitter switches and trailer brake control,i'm not sure though cause i got the split bench seat and a 6 speed tranny, but i'm open to suggestions, i'm planning on mounting my antenna on the side of my cross box ( i got a wilson fgt 4 top loaded antenna), and i got 18 foot of rg58 au coax to hook it up, any help or suggestions are appreciated
thanks
Old Apr 1, 2009 | 11:22 PM
ReAX's Avatar
ReAX
That's pretty much where I have mine mounted and it's a nice location. I did use a peice of think steel to spread the weight of my galaxy DX73v across more of the plastic. I don't think it will interfere with the shifter. My dash section was curved, so I inletted it so the bracket sits flush against the plastic, this set the radio back about 1/2" further. Also make sure your tool box is well grounded. I've installed a lot of tool boxes using J hooks and clamps, these are not good electrical connections. If you have a bolt on each side going into clean metal on the bed rails it's probably okay.
