Sponsored by: Innova
08 expy wiring problem
Old Apr 1, 2009 | 02:40 PM
almbon's Avatar
almbon
I have been tring to wire up an outlet to plug in my Sirius Starmate that turns off when I open the door just like the radio does. My thought is to find the wire in the harness for the radio that does that, but I can't find the color code anywhere. I know someone here has done this HELP
Old Apr 1, 2009 | 11:28 PM
ReAX's Avatar
ReAX
I didn't 08 expedition wiring, but this F150 should be very close. Just confirm everything with a meter to be sure.
Battery LIGHT GREEN/VIOLET (+) RADIO HARNESS
Accesory LIGHT GREEN/YELLOW (+) RADIO HARNESS
WILL BE PINK/BLACK ON XL AND STX MODELS.
Ground BLACK (-) RADIO HARNESS
Illumination LIGHT BLUE/RED (+) RADIO HARNESS
LF Speaker (+) ORANGE/LIGHT GREEN
LF Speaker (-) LIGHT BLUE/WHITE
RF Speaker (+) WHITE/LIGHT GREEN
RF Speaker (-) DARK GREEN/ORANGE
LR Speaker (+) GRAY/LIGHT BLUE
LR Speaker (-) TAN/YELLOW
RR Speaker (+) ORANGE/RED
RR Speaker (-) BROWN/PINK
Steering Cntrls OPTIONAL
Speed Cntrl YES
Radio Security YES
If you wanted to make the stock power point work with the radio, then pick up a relay. Cut the power wire on the power point, LT GRN/Ylw (switched) to 86, ground 85, 30 to the power point and 87 to the other side of the wire. Now, when the radio is on, the relay is tripped and the power point is hot. When the radio is deactivated, the power point is shut down.
