Spark Plug Gap
Old Apr 1, 2009 | 11:15 AM
daddy172005's Avatar
daddy172005
Spark Plug Gap
I recently lost the engine in my 74 f100. i replaced it with a shortblock 302 from an 80 thunderbird retaining all the other stuff from the 74. My question is about gapping the spark plugs. Do i gap the plugs to the 74 specs or the 80 specs? I checked the plugs and they are at .045. Not quite sure how that happened since they are supposed to be .035. Any input would be appreciated.
Old Apr 1, 2009 | 11:34 AM
fmc400's Avatar
fmc400
MSEE
Set it to the '80 specs. Spark plug gap is a function of firing voltage. Your '74 probably had points and the '80 probably has Duraspark, so it's even more important to use the '80 specs. It has nothing to do with what engine used to be in the truck, assuming you kept the ignition system from the T-bird.
Old Apr 1, 2009 | 11:37 AM
restoringmy46's Avatar
restoringmy46
I did the samething in my 79. It has a 91 302 block and heads but everything eles is 79. I use all the 79 specs. and it works great. So I would go with the 74 specs. since you just changed the block.
Old Apr 1, 2009 | 11:39 AM
fmc400's Avatar
fmc400
MSEE
You need to find out if he has points first. If you set a Duraspark ignition system to the gap of a points system, you'll burn out the plugs. I'm under the impression he took the entire 302. I don't think a 302 and 400 distributor are interchangable (could be wrong though).
Old Apr 1, 2009 | 11:48 AM
daddy172005
i just used the block and internals from the thunderbird and used everything else from the 74. The distributor is a stock points distributor.
Old Apr 1, 2009 | 11:54 AM
fmc400's Avatar
fmc400
MSEE
Okay, I take that back then - you need to set it to the '74 specs if you're retaining the stock points distributor (the gap is much lower than that of an '80 Duraspark system).
Old Apr 1, 2009 | 12:27 PM
daddy172005
I have another question. How do you tell if a plug has fouled? Thanks for your help.
Old Apr 1, 2009 | 12:42 PM
daddy172005
I gapped the plugs at .035 and at idle it seemed to run the same. I have a ticking coming from the front drivers side. The motor that blew had the same ticking in the same spot. since i used the same head with the same spark plugs i figure it has something to do with the head on that side. Could the carb needing adjustment cause this or anything else i can check fairly easy? The motor runs good and smooth but it just has an annoying tick to it.
Old Apr 1, 2009 | 06:03 PM
lasthighboy's Avatar
lasthighboy
exhaust leak at manifold? valve need adjusted? surely new plugs and wires so plugs in tight and wire not arcing?
Old Apr 1, 2009 | 07:33 PM
daddy172005
the valves are non adjustable. i havn't tried new plugs and wires even though i should have. money is alittle tight right now. its not an exhaust leak, new gaskets and no air coming from anywhere. thanks for the ideas. it could use plugs and wires so i guess should try that and see.
Old Apr 1, 2009 | 10:42 PM
fmc400's Avatar
fmc400
MSEE
Spark plugs should be clean and free of oil and soot. The porcelain should be a light tan color after you've got some miles on it. I'm assuming you are hearing the engine noise at idle when you're standing next to the motor? If so, that sound is coming from the lifters. One is either collapsed, or you have low oil pressure. Check your oil pressure with a mechanical gauge. It's not related to the carburetor at all.
Old Apr 1, 2009 | 10:46 PM
shanes66charger's Avatar
shanes66charger
likely a lifter tick. Solution?..........Drive it.
Old Apr 2, 2009 | 08:25 AM
daddy172005
It sounds like a lifter but its the second set of lifters and the noise is in the same spot. Its almost quiet at idle but gets louder when i accelerate.
c96drumm
3.8 & 4.2L V6
May 1, 2011 12:50 AM
Trevor1
Dec 7, 2006 11:32 PM
TN Hillbilly
24
Dec 25, 2004 10:59 AM
john
Jan 4, 2000 06:46 PM
