Towing help and axle code decipher needed...Apply within.
Old Aug 9, 2001 | 12:04 PM
StrangeRanger's Avatar
StrangeRanger
The tongue weight of the trailer adds to the GVWR and axle loadings of the truck but the entire weight does not. The entire weight of the trailer adds to the GCWR.
If someone out there has an owners manual will they please post the GCWR figures?
Old Aug 9, 2001 | 12:36 PM
webguyrich's Avatar
webguyrich
[font size="1" color="#FF0000"]LAST EDITED ON 09-Aug-01 AT 01:39 PM (EST)[/font][p]No, you have to add the weight (GVW) of both the truck and trailer together to find out if you are under the GCWR for the truck.
You only use the weights of the axles (GAW) to determine if your axles are overloaded. You also use the GAW to determine the total weight of the truck (GVW).
I apologize if I was unclear, I was in a hurry when I typed it out. The GVW of just the truck, minus hitch/pin weight, and the GVW of the trailer are added for toatl truck/trailer weight (GCW) and this must be under GCWR.
Rich
Old Aug 9, 2001 | 02:48 PM
rel3rd's Avatar
rel3rd
...... if you see an underpowered little red F-150 motoring down the highway with a purple race car on the trailer....YIELD.
Old Aug 9, 2001 | 03:18 PM
webguyrich's Avatar
webguyrich
Last post...
It has nothing to do with being underpowered, it has to do with being over weight. By the way most states are cracking down on over weight trailers. Have fun with the fine, if you don't cause an accident first. It just surprises me the lack of respect you have for your safety, your passenger's safety, and the safety of fellow motorists you are showing by knowingly grossly overloading a vehicle.
I personally would rather pay for five years on a new truck that I knew was rated for the job I wanted it to perform. God be with you and the other motorists you share the road with.
Rich
Old Aug 9, 2001 | 04:06 PM
rel3rd's Avatar
rel3rd
Last post...
Rich
Amen....Now go bother someone else.
Old Aug 9, 2001 | 05:39 PM
StrangeRanger
Deen,
No question that the rating is low, but that's at least in part because of the 3.08s. Since he's planning on changing his R&P to get more rating, what is the GCVR for an automatic and 3.55s?
Old Aug 9, 2001 | 06:16 PM
webguyrich's Avatar
webguyrich
Gross combined will never change. GCWR is based on frame, brakes, and trans I believe. There are way too many factors which make this truck extremely unsafe for this job.
Old Aug 9, 2001 | 06:51 PM
rel3rd's Avatar
rel3rd
Last post...
Rich
Rich,
SEE ABOVE
Please....enough is enough. You're wearing it out.
I think I'll buy a big old heavy enclosed trailer, with no electric brakes, just to spite you....
Old Aug 10, 2001 | 08:01 AM
DeenHylton's Avatar
DeenHylton
Deen,
StrangeRanger, my manual does not show the GCVR only GCWR and also maximum trailer weight by itself. With a light duty rear end and no tow package it does NOT change the maximum trailer weight ...even 4:10 gearing is a maximum of 2,000 lb. trailer weight.
My manual states: 1. Super cooling is required for trailers over 2,000 lbs.
2. Super cooling and Handling/Suspension Package are required for trailers over
3,500 lbs.
If he meets all the above requirements a 3:55 gear will give a maximum trailer weight of 6,200 lbs. and a GCWR of 10,000 lbs.
If he meets all the above requirements a 4:10 gear will give a maximum trailer weight of 6,900 lbs. and a GCWR if 11,000 lbs.
Deen Hylton
Ford F250 460 C-6, K&N, Headers, Dual Exh.,Comp. Cams,Shift Kit
Pioneer CD w/Bose Speakers.
Other Passion: Blown 77 Corvette (Sorry Guys/Gals)
How I can afford to Drive the above: 93 GEO Metro
Old Aug 10, 2001 | 04:45 PM
rel3rd's Avatar
rel3rd
Thanks guys.
Old Aug 25, 2001 | 11:21 AM
elliott's Avatar
elliott
Acording to my Old Childton manual that stops at 1985, 18 equals a 3.08 in 85. I'd guess it was the same in 86. Bob
Old Aug 27, 2001 | 08:31 PM
bulabula's Avatar
bulabula
Old90Uhaul
25
Nov 1, 2013 10:30 AM
jman92612
Oct 28, 2004 02:34 PM
Nathan Plemons
Aug 3, 2004 08:10 PM
rowdy200
1997 - 2003 F150
Jun 18, 2003 09:55 PM
Idaho
Aug 20, 2002 02:28 PM
