390--428????
#31
on
1 Post
with fe engines anything is possible. young kids were building these motors in the late 70s and early 80s doing all sorts of weird combinations because the parts were cheap and plentiful. its possilbe that 390 .060over pistons and crank could have been put in a 428block. i know of this goofy stuff because a friend of mine has a 360 truck motor with 428cj heads on it that his dad and my dad built in the 80s because they had the stuff just laying around.
Cough Cough..... a 4.110" piston in a 4.130" bore? LOL..Musta had one hell of some piston slap.... and I damn sure dont know what kept the rings in the piston ring lands??
#32
#33
I see you're new here
Incorrect.
This is NOT the first time I've heard of a block that looked to be a 428 by casting numbers was NOT a 428 block.
This is exactly the reason that most of the time the only way to definitively tell what FE you have is to physically measure the bore and check the stroke.
A quick google shows quite a few people who have/had C7ME-A blocks that were 390 GT's originally.
Incorrect.
#34
while understanding that looking at the casting numbers won't tell me what engine I have exactly, I am trying to get an educated guess here please.
This is what I have on the passenger side of the block. C6AE 6015 H
Any guess as to what this might be? I haven't taken it apart and wasn't necessarily interested in doing so.
TIA,
Mark
TIA,
Mark
#35
TIA,
Mark
TIA,
Mark
Our FE engines are over 40 years old. Most of them have been rebuilt, some many times. As you have been reading, the ONLY sure way to tell what you have is to take it apart and see. If you do not want to do that then just enjoy your engine and keep the oil changed. If it lasts over 300,000 miles, then you probably have a 360.
#36
Mine has a reversed image 105 instead of the 352. :)
"Ford never learned how to make the same part twice ;)"
-my Chevy buddies
Just to stop any "second guessing" of my pickup's parts before it starts...
'75 F150 360FE T18 9inch, I special ordered it when I was 21 years old.
Besides having the engine overhauled by a friend of a friend and having the
frame straightened at a dealership, I've basically done all the work on it.
Alvin in AZ
ps- George Benedum, Willcox AZ, R.I.P.
pps- Had already drilled out the drain plug holes and re-tapped them for 3/8"
pipe. The plugs are steel with a 7/16" square head, an impact (1/2"drive)
knuckle with a 7/16" 8-point-socket and 20" extension works about perfect.
Yeah, I got my block back. ;)
-my Chevy buddies
Alvin in AZ
fordtruck44
22
09-01-2008 10:30 AM
Mark-I6
28
02-03-2006 02:48 AM
Brad Brown
01-09-2005 12:30 PM
ford390gashog
06-27-2004 01:45 AM
