Engine revving
Old Mar 31, 2009 | 10:36 PM
MacAttack8401's Avatar
MacAttack8401
Engine revving
I have a 79 F-150 400 V-8. It has recently started revving the engine sometimes when I slow down or put it into park. Does anyone know what this is?
Old Mar 31, 2009 | 10:51 PM
fmc400's Avatar
fmc400
MSEE
Do you mean surging? Like randomly revs up and down on its own?
Old Mar 31, 2009 | 10:58 PM
Holiver31's Avatar
Holiver31
like fmc said if it is surging then that is not normal but if it is a constant "rev" then you need to adjust your idle
Old Mar 31, 2009 | 11:03 PM
fmc400's Avatar
fmc400
MSEE
I didn't say surging is normal; in fact it's not. Surging indicates a float level problem or a vacuum leak.
Old Apr 1, 2009 | 01:18 AM
MacAttack8401
ya, it's more of a surging...
Old Apr 1, 2009 | 01:22 AM
MacAttack8401
And I'm not sure why it is saying I own a Chevy...I would never be caught dead with one....what's going on?
Old Apr 1, 2009 | 07:36 AM
Holiver31's Avatar
Holiver31
i didnt say you did good luck
Old Apr 1, 2009 | 07:52 AM
fmc400's Avatar
fmc400
MSEE
I apologize Holiver, I did not see the "not."
Old Apr 1, 2009 | 08:36 AM
fasthauler's Avatar
fasthauler
My 77 is doing the same thing. The rpm’s are up when pulling up to a stop sign. It is a major bitch to get that thing stopped with that 460 pulling while you are trying to stop. I have discovered that I can put my toe under the pedal and lift up and it will go back to idle. That tells me that it is in the throttle mechanism, but I have checked out the throttle rod from the pedal to the carb and it is free and not binding on anything and I am clueless as to what is causing it. You might try to pull up on the pedal with your foot and see if you are having the same problem. That would give you an idea as to where to look. I will let you know if I figure out what is causing my problem.
Old Apr 1, 2009 | 12:18 PM
Pickupmanx2's Avatar
Pickupmanx2
Check on the carb, my 77 had a "dashpot" thing that was making it rev,,,
Old Apr 1, 2009 | 05:44 PM
Holiver31's Avatar
Holiver31
its all good
Old Apr 1, 2009 | 07:03 PM
Mr. Green Jeans's Avatar
Mr. Green Jeans
I had similar problem, more like wb6vvv describes, and it was the throttle return spring. It had stretched out over time and was not helping throttle return all the way back and letting engine stay "revved-up" a bit. Replaced spring, problem went away immediately.
Old Apr 1, 2009 | 07:33 PM
Opossum's Avatar
Opossum
Yes could be a throttle return spring problem.
But because you seem to say it happens when you hit the brakes it could be a brake vacuum assist going bad. They shouldn't actually allow much air into the motor via the vacuum line but if they devolep an internal leak they can.
Pay attention to see if it's all about the brake pressure.
