Help?
Old Mar 31, 2009 | 09:03 PM
1972fordf-100's Avatar
1972fordf-100
Help?
Hello all I have a 1988 Ford Ranger 2.3 liter with a problem. This truck doesn't want to start up it has spark compression but no fuel. Upon further inspection the injectors are not firiring when they are asked to by the computer. We have checked connections to the injectors and figured that they aren't grounding when need be. To clear the air the fuel pump and relay work fine but we are stumped about the injectors not firing. Any one else have this problem? Thanks for any help that you may give us we are starting to pull our hair out on this one.
Old Apr 1, 2009 | 08:56 AM
pawpaw's Avatar
pawpaw
The injectors have 12 volts B+ to them at KOER & the computer supplies the ground switching to fire the injectors, so maybe look to a wiring, electrical connector pin/socket, or poor computer ground connection, or internal computer component switching problem, with the computer itself.
Some thoughts for pondering, let us know what you find.
Old Apr 19, 2009 | 02:27 AM
1972fordf-100
Problem Solved
After some pondering we ended up replacing the ecm and that seemed to do the trick the truck starts and runs perfectly now. Thanks for the help!
Old Apr 19, 2009 | 01:46 PM
pawpaw's Avatar
pawpaw
OK, good feedback & to hear you seem to have put the fix on your fuel injector problem.
Too bad it was the computer, the most expensive part!!!!
