tow capacity
Old Nov 23, 2001 | 11:10 AM
daniel01's Avatar
daniel01
tow capacity
ok so i posted this question in supercrew section and now realize there is a dedicated tow section... here it goes
ok,,, i read the info on spec section and i'm still not sure ... what is the "standard" towing capacity of a 2001 4x2 5.4 liter with limited 355 screw without the class 3 package , and is it major work to have class 3 package done after the fact (not counting 1.4 inch rad, since it sounds like it may not be needed... i think????)
Old Nov 24, 2001 | 03:13 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
tow capacity
You'll have to look in your owners manual for the "standard" towing capacity. Most of Ford's literature lists the maximum towing capacity as "when properly equiped", meaning with the class III package.
Generally, 2,000 pounds is the max trailer weight recommended without a frame mounted hitch. The main component of the class III package is the class III frame mounted hitch and upgraded aux trans cooler. The rest is 7 pin wiring harness, HD shocks and battery.
It would not be 'major' work to have your Ford dealer or RV specialist equip your truck for towing.
[link:www.fordvehicles.com/trucks/f150supercrew/features/specs/index.asp?c1=&action=towing|Ford's towing capacities]
Old Nov 25, 2001 | 08:33 AM
daniel01's Avatar
daniel01
tow capacity
thanks for the info i wondered what "properly equiped" meant... i plan on putting in a frame mounted hitch, i hope that alone should handle 4000 pounds... i'll talk to the RV guys.
Old Nov 27, 2001 | 11:53 AM
oldblue18's Avatar
oldblue18
tow capacity
Mustang1966
Jul 30, 2010 06:52 PM
vtec
Escape & Escape Hybrid
May 13, 2009 10:29 PM
86rustbucket
Jan 20, 2005 06:54 AM
cobra413
Apr 1, 2003 10:35 PM
kickim1
1983 - 2012 Ranger & B-Series
Aug 14, 2002 01:17 AM
