Bronco II Ford Bronco II
wiper switch
Old Mar 31, 2009 | 03:11 PM
baddmove's Avatar
baddmove
wiper switch
is there a wiper relay i can replace? mine is still doing the high speed only , then the other 2 speeds will start to work..schuck's/Kragen cant find anything on there comp..otherwise, will i have to replace the whole switch?(steering column one)
Old Apr 1, 2009 | 04:22 AM
kernel-panic's Avatar
kernel-panic
I've heard of there being an external relay / capacitor bank for the switch, located somewhere either under the driver's side kick panel under the dash or under the dash. Not 100% sure on the validity of that. Might want to check it out. Otherwise, look at replacing the switch. Might have some bad connections somewhere, especially a bad ground connection.
Old Apr 9, 2009 | 11:56 AM
5.0B2's Avatar
5.0B2
If you have interval wiper control, there's a module that mounts on the inside of the firewall above the steering column and plugs in between the wiperswitch connector and the wiper motor.
