Oil in PCV pipe
Old Mar 31, 2009 | 02:38 PM
BRay09's Avatar
BRay09
Exclamation Oil in PCV pipe
On my 89 351w the PCV was making a weird noise so i bought another one and put it on there. I found that the old one was full of oil (well not technically "full" but there was alot.) and thought this was odd. I called advanced auto and thetech said that i have alot of blow-by and the motor may need a re ring for the pistons. Is this correct? Will this motor be going soon?
For this summer, im ordering a reman 351w long block and swapping in the Crane 444232 cam, GT40 heads, 1.7 RR, and long tubes. Thought this would be easier and cheaper than a rebuild on this motor.
Old Mar 31, 2009 | 04:14 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
He's probably right.
Rings, scored bores....something is pressuring your crankcase.
Old Mar 31, 2009 | 10:06 PM
my93's Avatar
my93
Suggest removing the vac hose from the pcv and check it for being plugged with carbon. And check the fitting or tube it is connected to into the intake for carbon build up also. Had the same systems you had and others told me I had ring and or blow by problems. Cleaned out all the carbon out of hoses and tube and in fact where the fitting of the tube connected to the manifold it was plugged up there also. After a thorugh cleaning had no more problems with crankcase pressure/blow by
Old Mar 31, 2009 | 10:36 PM
HrdDrv's Avatar
HrdDrv
Pull the pvc when at idle, and check for vacuum.
Old Apr 1, 2009 | 12:50 AM
88n94's Avatar
88n94
I would try a Ford Motorcraft PCV valve. On another site they claim aftermarket PCV valves cause all sorts of weird stuff.
Old Apr 1, 2009 | 06:05 AM
Lazy K's Avatar
Lazy K
Couldn`t agree more.
Old Apr 1, 2009 | 02:40 PM
BRay09's Avatar
BRay09
Thanks for the posts. Ill be sure to try these things and get back with an update soon.
Old Apr 1, 2009 | 02:54 PM
quicklook2's Avatar
quicklook2
if i remember right you need to move it to another place on the intake.
something about the #8 cyl.
do an advanced search.
Old Apr 1, 2009 | 03:02 PM
BRay09's Avatar
BRay09
like drilling another hole in the heads and relocating it? never heard of that before... ill look around for something on it.
Old Apr 1, 2009 | 04:09 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
My dad took his '97 F250 with the 460 to a lube joint for an oil change once when it was only a few years. He figured one oil change at a lube joint was not going to hurt anything. To make a long story short, they overfilled by about 2 quarts, and it filled up the PCV valve with oil and shot a bunch of oil into the air cleaner. After draining out the extra oil, there have not been any problems since. Check for overfilling.
Check for carbon buildup, hopefully that's your problem, and you don't have bad rings. Good luck.
Old Apr 1, 2009 | 04:18 PM
BRay09's Avatar
BRay09
The truck just had an oil cahnge. Ive been driving it for the last two days, and i will check the valve when I get home ad see if the oils built up in there again.
Old Aug 9, 2018 | 08:26 PM
frodo2222's Avatar
frodo2222
I need to change the vacuum hose from the PVC to the back of the throttle, does it just pull out or is there some kind of nut or something..I can feel where it goes but cannot see anything at all...any help? It's on a 1994 F250 2 wheel dr 460 motor
