Sponsored by: Real Truck
axle code question
Old Mar 30, 2009 | 09:03 PM
jonnysteals's Avatar
jonnysteals
axle code question
I already looked in the tech folder. My axle code is 37. its an 05 superduty diesel lariat. Does anyone know what gear ratios this is. Im hoping for 4.10s because I run a 38 inch tires. In the tech folder they list 36 which is 4.56 gears. I doubt I have 4.56 but trying to figure out what my truck came with stock. Im changing my rear diff cover and need to know if I have to add the clutch modifier. Does anyone know how much fluid I need to buy as well. Thanks.
Old Mar 30, 2009 | 10:46 PM
PowerStrokeHD's Avatar
PowerStrokeHD
37 = 3.73 Non-Limited Slip
Old Mar 30, 2009 | 10:50 PM
powerstroke72's Avatar
powerstroke72
I think you just didn't go far enough down the page. In the tech folder, it lists 37 as 3.73 open diff. Look down in the SD tech folder at post #9 by IB ADRIAN.
Old Mar 31, 2009 | 07:27 AM
jonnysteals
thanks guys. Guess i needed to look a little harder. Sorry. Does anyone know how much fluid the rear diff holds and what fluid. Im off to the tech folder now but trying to figure out what brands people like. Only want to do this once.
