I am putting a 289 into my 1994 ford aerostar, and I was wondering in what vehicals are the FI289, theres no room for a carb under the hood so FI is needed, So what year of cars/trucks did a FI289 come in?
I would imagine that the fuel injection system from a 5.0 (302) would work on a 289. Just make sure to avoid the early 1963-64 289 with the 5-bolt bellhousing. It won't attach to newer transmissions.
I think you have a misunderstanding of what the cubic inch size of an engine refers to. It refers to the volume of displacement which is determined by the bore and stroke of the engine. The external dimensions are NOT determined by the cubic inch side.
I would expect that it would be pretty difficult to find a V8 with smaller dimensions than a 302 Ford. There have been a few V8's built with smaller external dimensions, but they are not common or easy to find. This aggravates your situation when trying to find parts or hop up items.
Have you googled something like "V8 Ford Aerostar" or some such? I would not be surprised if there are kits available to facilitate such an engine swap. You might at least find some information from someone who has done it or tried it.
I have seen a 302 Aerostar before, but IIRC he moved the firewall back, The 4.7L is about the same size as the Ford 4.0L, I will probably put a 302 in it.
