hardwiring a fuel pump
Old Mar 30, 2009 | 03:55 PM
colorsink's Avatar
colorsink
hi i have a 90 f150 4.9 what wires would i hook up to a switch to activate the fuel pump for testing purposes
Old Mar 30, 2009 | 04:02 PM
RIKIL's Avatar
RIKIL
I am taking a guess here but this might get you started...
Sounds like you have only a single tank. On your instrument panel, just to the right of your headlight on/off switch, you should have a blank spot in the plastic. Behind that blank spot are some wires relating to your fuel pump. This is the spot where a front/rear switch is normally put. If you take off the plastic for the instrument panel, which takes less than 10 min, and supply power there, it might get you what you need. I think that is what I used on my 92 F150 to power it on.
Old Mar 30, 2009 | 04:03 PM
1966Tbird's Avatar
1966Tbird
there is an enertia switch to the right of the big plug that goes into the firewall behind the brake pedal, the lighter color wire goes to the enertia switch then the darker wire goes to the pumps
Old Mar 30, 2009 | 06:51 PM
colorsink's Avatar
colorsink
so if i wire it from the inertia switch will this bypass the relay?
Old Mar 30, 2009 | 06:54 PM
subford's Avatar
subford
Yes it would.
Old Mar 30, 2009 | 09:27 PM
EPNCSU2006's Avatar
EPNCSU2006
You can also manually force the relay to energize by jumpering the fuel pump wire to the signal return wire in the diagnostic connector under the hood.
rcfreed
Jun 26, 2015 01:20 AM
midsouth
Sep 27, 2014 07:40 PM
jcalebw
May 12, 2014 06:05 PM
biggyfan1
48
Oct 31, 2013 07:26 PM
mauicruza
1966 - 1977 Early Broncos
13
Feb 10, 2005 05:37 AM
