Towing with 99 Ranger
Thanks you!!
[ellis@safezone.net]
captntim
'86 F150 4x4 300I6 SWB NP205 4speed
high flow cat; dynomax turbo muffler
stock tire size
Draw-Tite class III weight carrying hitch
home-made brush guard and roll bar
she's not quick...but it'll pull just about anything
James
>you do you're pretty much out of luck on towing much. I
>would say if you do have the 4 cylinder then you've got a
>lot of things to add before towing. Better spark plugs,
>Jacobs electronics, new air intake with a K&N cone filter,
>MAFS, headers, performance cat, exhaust, and a chip. And
>guess what, thats just the engine improvements to give you
>more power to tow with. And it still might not be enough.
>If you've got a 4 cylinder you're looking at like 90HP stock
>(or so I hear). With the things I just listed you should be
>able to hit about 250HP without even pulling the engine
>apart yet or changing gears. I guess the best I could say
>is load your truck with as much gravel as you can fit in the
>bed, then borrow a trailer from a buddy, strap about ten 10'
>logs on it and try hauling it for about 50 miles. Should
>give you a real good idea on what you can hual.
>James
Dude, I don't think a couple of bolt on parts will take a 4cylinder to 250hp
Chris
79 F-150 Lariat: Long-bed, 2wd, 460 (intake, headers, cam, early heads), C-6 (shift kit)
79 Mustang: 460 swap under way, balanced rotating assembly, forged pistons, truck rods, c-8 heads ported, Lunati solid lifter cam, more stuff...
98 Chevy Silverado ext. cab 4x4 (work truck)
95 Lexus SC300 (wife's baby)
really though...don't tow the trailer, you'll regret it
captntim
stock tire size
>4cylinder to 250hp
>Chris
Its been done in the past and its going to be done again. Sorry if you haven't seen it done before. Just gotta know what you're doing or have a friend or two who does.
James
Looks like I'm trading in my Ranger for a bigger truck.
Although I am a Texas girl, I'm not really wanting a BIG truck. Any recommendations on the smallest truck I could get that would safely haul a mid-size hybrid camper (5000-6000 lbs. loaded)? Thank you! --Denise
Good luck with whatever you choose.
If you are in southern Texas and don't get any snow and won't be towing anywhere tricky - you could go with the 4x2 and no limited slip axle. IF however, you have snow or icy roads and slippery camping areas, then limited slip and perhaps even 4x4.
I"ve been super happy with my 4x2 F150 with 5.4 with limited slip rear end, but I live in a snowy/icy area. I simply put about 6, 50 pound bags of sand in the back end of the truck during the winter.
With the 4x2 you can tow 5000 pounds of trailer and still load up the truck bed with other stuff. Don't go over 5000 pounds towing because the class III hitch is only rated that high. You can tow more, but you need to add a weight distribution hitch.
With a 4x4, you are still limited to 5000 pounds because of the hitch, but you can't pack as much stuff in your truck as with the 4x2 because otherwise you'll exceed your GVWR.
4x2 is better gas mileage whether towing or not towing. And it has LOTS of get up and go with the 5.4 litre engine.
I happen to know of a super nice 4x2, 2000 F150 that will be coming up for sale in the next few weeks... it's the one I just traded in. It's chestnut brown with gold along the bottom (like the King Ranch Crew Cab trucks) and has gold upper pin striping and red lower pin striping. It'll be priced around $16k and has less than 40k miles on it. It's the one I just traded in and will be going to southwest US for auction. There's no market in Detroit for used trucks.
