Sponsored by: Real Truck
Springs
Old Mar 30, 2009 | 10:34 AM
bc56845's Avatar
bc56845
Springs
I put an add a leaf in my '99 250 7.3 a couple years ago. I was trying to level it and wasnt impressed with the results. Well I think the springs may have already been sagging then, but now I think they're back down to below where they were before the add a leaf. Anyway, I want to get this thing level once and for all. I can get a set of used x-code springs off of a f-450 for 150 bucks. Will these really level it out, or just almost? Any other options in aftermarket springs? Thought about just adding a shackle to it and get a little more, but I want to do it right and be done with it. Thanks in advance
Old Mar 30, 2009 | 12:11 PM
JIM_C's Avatar
JIM_C
Yes, the X-codes will get you there, if you have 2" blocks in the rear. The reason I say that is because I seem to recall (maybe incorrectly) that some early 99 F250s had 4" blocks in the rear like a SRW F350. If you do have 4" blocks in the rear then the X-codes will still be a great improvement but won't level it out.
Old Mar 30, 2009 | 02:06 PM
bc56845's Avatar
bc56845
how much stiffer are the x -codes gonna be?
Old Mar 30, 2009 | 06:36 PM
99f350sd's Avatar
99f350sd
I don't think you will notice a problem withthe x's..I went from v's to x's and my plow book said 2" difference..I like the way it rides with x's. But its a truck..
Dick
Old Mar 30, 2009 | 11:22 PM
bc56845's Avatar
bc56845
Well I guess I could go ahead and stick in the x's and if they dont put it up where I want it then I could always put the add a leafs that I have in my current springs in the x codes, right?
Old Mar 31, 2009 | 09:06 AM
99f350sd's Avatar
99f350sd
yes sir.....
Old Mar 31, 2009 | 11:57 AM
JIM_C's Avatar
JIM_C
Yyyyyep. How old are the X-codes from the F450?
