Sponsored by: Real Truck
passenger airbag switch
Old Mar 31, 2009 | 07:57 AM
west tn 6.0 powerstroke's Avatar
can someone tell me where the passenger airbag switch is and how to go about changing it out. the light on the dash in the lower right hand corner flashes when i first crank the truck and then it stay on as i am driving. the truck is a 2004 ford f-250. the light on the switch that you use the key to turn the passenger airbag off does not work it should come on when you turn the key on to crank the truck but nothing happens i just run with it off now in fear of it malfunctioning and blowing out going down the road any help would be appreciated thanks
Old Mar 31, 2009 | 12:05 PM
bpounds's Avatar
bpounds
Not sure what you are asking. Wouldn't the passenger airbag switch be where you stick the key in to turn it off? The switch should be right there.
But I think your truck is trying to tell you the airbag is not testing okay at startup. The dash light should come on every time at POST, but go out if the circuit tests okay. Yours is not testing out as okay.
Smokdivr28
1997 - 2003 F150
Aug 20, 2021 06:50 PM
Bartman1959
Jun 7, 2017 07:21 PM
Boilermaker1994
Sep 18, 2016 12:09 PM
bigjons
1997 - 2003 F150
Nov 26, 2011 03:14 PM
n5926g
2004 - 2008 F150
Aug 8, 2009 11:30 AM
