installing new camshaft sensor problem
Old Mar 30, 2009 | 09:57 AM
ktnstubblefield's Avatar
ktnstubblefield
Exclamation installing new camshaft sensor problem
We have a 2001 Ford F150 full size pickup truck. We had the CEL come on and had it checked and it came out to be the idler cam sensor. We bought a camshaft sensor and took the old on off. When we went to put the new one in, it just wont go down on it all the way. We thought it might be the wrong part, so we took the old one and new oneback to the parts store and they said they are the same thing. Same part! But, we just can no get it to go back on it. Would it be possible that the "C" shaped thing in it, is not in the right position? The "C" is half off to one side and half near the opening. Can we just bump the motor over and get the "C" in whatever position it is suppose to be in? Or what do we do?
Old Jul 7, 2009 | 12:48 PM
jaypro's Avatar
jaypro
did u find tdc of the number one cyclinder before you took out the sensor?
Old Jul 7, 2009 | 03:35 PM
MH1949's Avatar
MH1949
It sounds like you are just changing the black top and not the whole assembly.
Check the C to see if it moves from side to side the bearing may be loose and the C is off center this would keep the top from going down. You may need the whole assembly. Note this needs to be timed.
Old Jul 16, 2009 | 03:42 PM
F4L956's Avatar
F4L956
Smile
ktnstubblefield did you get the problem fixed. also any particular reason why you changed sensor did you scan some codes etc..?? i have a problem with a code p0340 engine stalls, shudder etc. i plan on doing the sensor swap but 1st need to trouble shoot 1st for shorts on wirin then sensor then just alignment on sensor sync. dont know yet what the problem is
got this when it rains heavily it gets really bad to stall can only go at low mph try to step on it it just misfires rapidly its crazy any feedback be greatly appreciated... my ride f150 4.2 01'
number20
2004 - 2008 F150
Jun 24, 2016 01:02 AM
stececcato
Nov 11, 2015 09:08 AM
chevy305dbt
2004 - 2008 F150
May 19, 2013 12:18 PM
Peterand
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 18, 2009 11:10 PM
Torque1st
Oil & Lubrication
36
Dec 17, 2005 11:12 AM
